Old Dec 20, 2007 | 07:02 PM
  #351
Fox Fader's Avatar
Fox Fader
Default RE: What Did You Do To Your RAM Today?
ORIGINAL: SilverRam_01
Washed it, actually cleaned the interior... saw some pics of Fox Fader's awesome blue beast, and decided to try to clean my motor with a toothbrush and a rag and failed....
Wow, thanks for the props. It ain't easy, took me bout 10 hours total. Anyone can do it.
Old Dec 20, 2007 | 08:25 PM
  #352
92GreenYJ's Avatar
92GreenYJ
Well Lets see, yesterday I did a tune up in hopes of fixing a Cylinder #4 misfire trouble code I've been throwing. new plugs, wires, cap and rotor. Then I did the round Air Cleaner Mod with an Edelbrock 14" Air Cleaner assembly. Today I went ahead and finished up the AC install (needed some all thread to make an s-bolt) Then I turned my attention to the sound system. Replaced the speakers in the back door with some Eclipse 3 ways then moved the stock rear speakers to the secondary speaker holes in the rear doors for the heck of it (stock wiring Eclipses are on a Clarion 4 channel amp) then I replaced the stock 6x9s only to discover the old ones i had that i replaced them with are completely screwed. GTuess I'll have to get some new ones to drop in when I get my e-bay power window switches (my drivers side is screwed)
Old Dec 20, 2007 | 09:39 PM
  #353
DodgeFan01's Avatar
DodgeFan01
Replaced the front driveshaft, the older one was loose and vibrating like hell, the spines were all flattened down. Not much wiggle room now, much better!
Old Dec 25, 2007 | 06:25 PM
  #354
dhvaughan's Avatar
dhvaughan
changed engine oil and transfer case oil (AT fluid). t-case held about 1-1/2 qt. damn recessed aluminum hex plugs - i thought the fill plug was going to strip, AFTER i'd removed the drain plug and all the oil. also replaced IAC to stop surging cold idle. had replaced it in '06, and it didn't even last a year. also replaced air cleaner gasket. reset pcm.
put front strut/shocks on daughter's 4-runner yesterday. first time i'd ever used a strut spring compressor - pretty cool. replaced the rear shocks today.
Old Dec 25, 2007 | 06:40 PM
  #355
v10power's Avatar
v10power
Well its not today but over the weekend i did a tune up on the 1500 with the 360 and go figure i broke off 3 plugs in the block. PITA to get them out with an easy out and such. And well tomorrow or maybe thursday i get to have the fun job of tearing down my 3500 with the V10 and doing either an injector swap or in hopes to just clean them, i'm just looking to sell the truck and get a diesel. I'm sure i'll find something else to tackle while i'm at it, always do.
Ken
Old Dec 27, 2007 | 12:25 PM
  #356
JCliffordd's Avatar
JCliffordd
Brought it to the stealership for the Trans Bands and TC Cable adjusted hoping this works with the ****ty shifting[:@]
Old Dec 27, 2007 | 05:35 PM
  #357
aim4squirrels's Avatar
aim4squirrels
Ordered Harland Sharp Roller Rockers in the 1.7 ratio...
Old Dec 27, 2007 | 05:44 PM
  #358
SilverRam_01's Avatar
SilverRam_01
Hosed it down, and found out that the ACE satin black rust-stop paint is practically tough as line-x. :P I scrubbed it with a stiff bristle brush, and it didn't even scratch it. Got some Vicodin out of the glovebox.
I've been looking, are 1.7s a better way to go over a cam if you're funds limited?
Old Dec 27, 2007 | 06:50 PM
  #359
kowboydmac's Avatar
kowboydmac
Replaced IAC. Got the black RTV for the future water pump swap; hasn't leaked at all though since 2 weeks ago, kinda mysterious there. Doesn't run much hotter than 205-210 with the stock 195 TSTAT either.
Old Dec 28, 2007 | 06:34 PM
  #360
8t5gt's Avatar
8t5gt
drove it like i stole it
