Old Jun 9, 2010 | 08:27 PM
  #3961
bigslick050's Avatar
bigslick050
Traded in an old century camper top from a ford long bed for a new over-the-rail drop-in plastic bedliner for the truck today. U guys would not believe the hell I went through to get the toolbox on and mounted without cutting gapping holes for the mounts. Still not a single hole drilled in my bed caps though.
Old Jun 11, 2010 | 04:28 AM
  #3962
jsbigone's Avatar
jsbigone
Default Tonneou cover
Finished the airbrush work on Tonneou cover and cleared It finally. Have a trip planned next week to ride the bikes down to Hot sprinks, Arkansas for a party week. Plan on doing the Airbrush work on the bed and reclearing it when i get back! That is as long as I keep the rubber down on the road and not my head!!
Attachment 9132
Old Jun 11, 2010 | 09:39 AM
  #3963
bigtman07's Avatar
bigtman07
Ok how did you manage to get a toolbox in the bed and keep it there without drilling holes in your bed?? I want a toolbox but I can't bring myself to drill holes in a perfectly good bed.
Old Jun 11, 2010 | 10:07 AM
  #3964
mnewbolds's Avatar
mnewbolds
The box I installed came with hook bolts that catch underneath the bed rails and have flat washers and bolts that go inside the box.
Old Jun 11, 2010 | 10:29 AM
  #3965
bigtman07's Avatar
bigtman07
Ok I need to get me one of those
Old Jun 11, 2010 | 04:04 PM
  #3966
1997DodgeRam's Avatar
1997DodgeRam
Same here, mine mounts the same way. It's been mounted there solid going on 6 years now, came with little foam pieces that get compressed between the rails and box as you crank down on the bolts.
Old Jun 11, 2010 | 04:39 PM
  #3967
dodgeram07's Avatar
dodgeram07
i just used a piece of thick flat scock and put a blot and rut throw it
Old Jun 11, 2010 | 04:51 PM
  #3968
UnregisteredUser's Avatar
UnregisteredUser
Mine's a lot like the others who've responded, but I've got a BackRack which leave the j-bolts that came with the Delta box too short. I couldn't find any suitable j-bolts at the hardware store, so I got hook bolts, rebent the hooks into J's, and covered them with some stout vinyl tubing. With four of them on there I think it'd take a wreck much more violent than I'd survive to knock the toolbox loose. Not that I intend to test my hypothesis.
Old Jun 11, 2010 | 05:24 PM
  #3969
rwisaacks's Avatar
rwisaacks
Old Jun 11, 2010 | 08:39 PM
  #3970
bigslick050
I bought a mount kit at AZ which is basically to plastic blocks that clamp together at the bed rail. Then the outside block has two holes (horizontal) where you mount the box over top and bolt through the holes. The J hooks are the cheaper option that do the exact same thing.
