Old Jul 13, 2010 | 09:59 PM
  #4171
mnewbolds's Avatar
mnewbolds
Originally Posted by rwisaacks
What does "bed the new pads to the disks" mean?
AKA "break in" period. I usually start by going 5mph and come to a slow stop, 15mph-slow stop
25mph- so on and so forth to about 55-60 and do that a few times. What that does is run the pads and rotors through all heat cycles. Just don't Jam the breaks for the first 100 miles or so. Although you should never have to do that anyways, makes them last longer if you don't.
Old Jul 13, 2010 | 10:28 PM
  #4172
dsertdog56's Avatar
dsertdog56
Welded a plug into the hole where my tire winch used to be.
Applied some bondo to level things out. Bondo does not like high humidity.
Ground off some rust on the hitch.
Old Jul 13, 2010 | 11:05 PM
  #4173
Basically, take it out and beat on your brakes a bit..... Run it up to 50, step as hard on the brakes as you can without locking up.
I never really bothered with this procedure after having it warp rotors on customer cars a couple times. If there is a good non-directional finish on the rotors, normal driving will suffice.
In all reality, I wonder if the procedure is just a hold-over from the days of asbestos brake pads......
If it were a race truck, I would actually consider doing it...... but, for a daily driver, in my opinion, it isn't really necessary.
Old Jul 14, 2010 | 12:04 AM
  #4174
dodge15004x45.9's Avatar
dodge15004x45.9
Drop it off at the gear shop.
Old Jul 14, 2010 | 07:47 AM
  #4175
Gomer03's Avatar
Gomer03
Well....I ordered a new drivers side Hub and wheel assembly, and U-joint (drivers side...passenger was replaced last year)....and.....bought these: http://cgi.ebay.com/ebaymotors/94-01...ht_5472wt_1165
Opinions?
Old Jul 14, 2010 | 10:38 AM
  #4176
Originally Posted by Gomer03
Well....I ordered a new drivers side Hub and wheel assembly, and U-joint (drivers side...passenger was replaced last year)....and.....bought these: http://cgi.ebay.com/ebaymotors/ws/eB...d=478144402013
Opinions?
Link goes nowhere.
Old Jul 14, 2010 | 10:47 AM
  #4177
offroadjosh's Avatar
offroadjosh
Changed the read diff fluid.
Old Jul 14, 2010 | 12:01 PM
  #4178
Sheriff420's Avatar
Sheriff420
Originally Posted by BlueBeast2
I replaced the IAC,TPS, and MAF without disconnecting the battery and I didn't get a code. I had to remove my air cleaner so I had the one in it (that's the IAT right?) unplugged and had no problems
I thought it was weird. I've unplugged my TPS and IAC at least 15 times since I've had the truck and I've also had the MAP and IAT (it's in the air cleaner now) unplugged a few times and never thrown a code but it did this time.
Old Jul 15, 2010 | 07:03 PM
  #4179
Gomer03's Avatar
Gomer03
Link goes nowhere.
I apologize....fixed the link.
Old Jul 15, 2010 | 09:10 PM
  #4180
Those look kinda cool. The funny finish inside the inboard lights looks odd though, might just be the pics. Post pics when you get them installed.
Price isn't too bad either.....
