Hopefully fixed my occasional hanging up idle/ fluctuating idle at stops, with a new IAC sensor. Truck "seems" to idle much smoother through red lights now.
Also got my modified manifold painted. Just need a set of fuel rails to paint red. Valve covers to paint red. Tstat housing bolts. Manifold gaskets/ bolts, and new injector o-rings, and I'm ready to swap I think....I'm sure I'll realize something the day of swapping though. Never fails.
Looks real good buddy! Looks like you are on your way. If there was advice to provide, it'd be take your time and be meticulous to your own degree of sanity.
tooooo logical.
Filled up from 3/8 of a tank. Cost $76. I got 14.0 MPG! Best I have ever seen in the truck. That was with a few full throttle runs scattered in there and one burnout
Fixed my coolant leak. Upper hose was a little loose the thermostat housing causing a small leak. Changed t-stat gasket as well.
Next up- Fix my wiper and hi/low beam problem when i get the security t-20 torque wrench to take apart steering column
Have you tried putting those two pistons back into the motor? It might have a better chance of starting that way
no....that can't be it.
The knuter valve is wide open. It should crank right up
but this guy might help anyone with issues with said valve
http://www.youtube.com/watch?v=MXW0bx_Ooq4
