Old Nov 26, 2009 | 12:29 PM
  #2071
004x41500's Avatar
004x41500
Originally Posted by Sheriff420
see if the low side of the valve cover has any oil around the gasket. my plugs used to get a good little bit of oil on them from a bad valve cover gasket leak. it did make the plug heat shields easy to pull out though.
whats up with the heat shields? ive never seen them on a dodge till i got mine. my stepdads 95 318 didnt have them
Old Nov 26, 2009 | 12:33 PM
  #2072
Sheriff420's Avatar
Sheriff420
umm... they shield the plug wire boots from heat?
a bunch of people yank em off without any issues but they don't bother me so i leave them on. and like i said, oil on them makes them easy to take out and put back in.
Old Nov 26, 2009 | 01:02 PM
  #2073
NAILS's Avatar
NAILS
Default me and my awsome 1998 dodge ram 1500 4x4
moved my iat sensor, cleaned my throttle body, and smoked my tires big time boys
Old Nov 26, 2009 | 04:45 PM
  #2074
95MaroonMonster's Avatar
95MaroonMonster
not a damn thing, heard someone start it to move it this morning so they could leave with their car (parked behind them)
i can now hear it from my room, i like that
Old Nov 26, 2009 | 05:33 PM
  #2075
004x41500's Avatar
004x41500
well guys i started lookin at hella 500s, and well i thought that id upgrade the 55w halogen to 6K HID, do you think the hella lens' will hold up to the hids?
Old Nov 26, 2009 | 06:18 PM
  #2076
Oren09's Avatar
Oren09
Probably that. The valve cover gaskets are leaking a good amount. Might be where my oil goes because I don't think my plenum is bad. I got some semi-fresh oil on my hands from the cylinder heads. I'm thinking FelPro cover gaskets from Summit for $36. Are there good? I was also thinking about doing HS 1.7 roller rockers and new valve covers while I have things apart. (I'd really like the Mopar Performance black wrinkle ones that say MOPAR MAGNUM, but they're like $200)
Old Nov 26, 2009 | 06:33 PM
  #2077
PurplDodge's Avatar
PurplDodge
You can get new gaskets at NAPA. No need to order a common gasket.
Old Nov 26, 2009 | 06:58 PM
  #2078
Sheriff420's Avatar
Sheriff420
felpro is good. i got mine at advance. and if you haven't done your plenum then it is leaking. i thought mine wasn't leaking too bad until i pulled the throttle body off.
Old Nov 26, 2009 | 07:33 PM
  #2079
xjarhead69's Avatar
xjarhead69
I spent Monday thru Wednsday replaceing automatic tranny in my truck and added tranny cooler. Still have to adjust TV cable, 8 quarts of tranny fluid and still not topped off yet.
Happy Thanksgiving Everyone.
Dave
Old Nov 26, 2009 | 08:21 PM
  #2080
004x41500's Avatar
004x41500
Dave
im not 100% sure but i do believe the full system should take around 11 quarts, thats with a torque convertor being filled as well. i think there should be like 7 quarts total in the pan...
again im not 100% sure about this, but im sure someone will chime in...
and anyways does anyone happen to know if the hella 500 lens will hold up to an HID upgrade?
