Old Dec 26, 2012 | 06:25 PM
  #9571
dlyter09's Avatar
dlyter09
Well if this job comes through for me I will for sure be going to 3/4 ton suspension.. Id be willing to let my Yukon 4.10 go
Old Dec 26, 2012 | 06:27 PM
  #9572
aofarrell2's Avatar
aofarrell2
Originally Posted by dlyter09
Well just get a good posi and some different tires... That should make things a little easier for you.
Naw, do a 4WD Conversion!
Old Dec 26, 2012 | 06:29 PM
  #9573
stewie01's Avatar
stewie01
Sweet. What kind of swap would that be like with my 3.55 rear?
I actually asked about that on this forum when I was a newbie. Even had a truck, slightly newer, that I could have yanked parts from...
Old Dec 26, 2012 | 06:33 PM
  #9574
dlyter09's Avatar
dlyter09
Be pretty straight forward.. Might need to have a shop set it up for you if you arent comfortable with doing it... I would be selling everything you would need for it..
Old Dec 26, 2012 | 06:39 PM
  #9575
stewie01's Avatar
stewie01
Awesome. You'll have to keep me informed!
Old Dec 26, 2012 | 06:43 PM
  #9576
dlyter09's Avatar
dlyter09
Will do
Old Dec 26, 2012 | 07:09 PM
  #9577
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Not all the lines are METAL though, to the brakes they are RUBBER, and Texas heat LOVES to eat rubber lines! Also if your calipers start wearing, the brake fluid will disappear seemingly suddenly. Happened here. My brake fluid is black, so desperately needs service, but they still work SOOO.....
As I stated earlier, everything except the metal lines has been replaced in the past 2 years, rubber lines included.
Old Dec 26, 2012 | 07:32 PM
  #9578
aofarrell2's Avatar
aofarrell2
Well check your disc brake pads. IDK if you have 4 wheel discs or not.
Old Dec 26, 2012 | 07:38 PM
  #9579
dodge dude94
Dude, the pads are 1 year old and the shoes are 2 years old. And it's not a matter of stuff being worn out, it's a matter of something making the fluid disappear. I started noticing the smushy pedal after basically racing my truck around on some back roads by my friend's place. I was pushing the truck kinda hard, only thing I can think of is leaking wheel cylinders or just evaporated brake fluid. Because it is a light brown and the new stuff I put in was clear.
Old Dec 26, 2012 | 09:24 PM
  #9580
Spillage's Avatar
Spillage
I had a master cylinder seal leak... bled the reservoir into the booster.
And as for pads, I got ~97k out of original fronts, and I'm still on original rears at 153k.
