The Official 2nd Gen RAM Forum OT thread
Old Jul 28, 2013 | 11:48 PM
  #10931
Ham Bone's Avatar
Ham Bone
I have a Husqavarna 223L that kicks ***.
The trick is to only buy them that have the black plate that say "made in Sweden"
Everything else is just an orange colored poulan
Old Jul 28, 2013 | 11:53 PM
  #10932
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Poulan isn't always bad!
I had a poulan pro-link powerhead that only died this year. 2007 date of manufacture. Needed a coil, recoil unit, and I think it may have lost some compression or had a gasket blow. Not sure.
Old Jul 29, 2013 | 12:03 AM
  #10933
Ham Bone's Avatar
Ham Bone
We had a poulan weedeater that died in two years. Biggest POS.
Now we have a 12+ year old chainsaw that is still going strong. The bar oil sprayer doesn't work tho, throws it all out as fast as it can in 5 minutes, cuts great if you can keep some oil on it
Old Jul 29, 2013 | 12:06 AM
  #10934
dodge dude94
Like I said, just depends on what you've got. lol
So far, our Echo stuff has been great. The chain saw has only cut down 5 trees, but they were all as large or larger than the saw is rated for. Two of which were old oaks that were petrified and were laced with 1 oz lead shotgun slugs.
Old Jul 29, 2013 | 12:09 AM
  #10935
Ham Bone's Avatar
Ham Bone
At work all we do use is Stihl. We had brand new FS90rsand we've ran the **** out of them this season and now they run like shat. If my boss would just pay to get the parts to let me service them
Old Jul 29, 2013 | 12:45 AM
  #10936
dodge dude94
I like the Echos because they're light and have explosive power. And in the case of the saws, they run K&N-style round air cleaners.
They look bad ***. It's just a shame you can't see it when you're operating the saw. lmao
Old Jul 29, 2013 | 12:29 PM
  #10937
Jigabop's Avatar
Jigabop
stewie: when is the last time you cleaned the jet(s) out in your mower and weed eaters carbs?
probably 95% of the time when those things wont start it is because a tiny spec of dirt/dust got sucked into the jet and jammed it up..
pull the fuel bowl off, and find yourself a bread tie, or some stranded wire...
peel the paper cover off the bread tie so it is just a bare wire, and run it through the jets a couple times. you can do the same thing if you have some electrical wire...take a single strand of the wire and run it through the jets. after you do that, clean the bowl out, put it back on, prime it and start it...it'll fire right up and run like a champ after that
would suggest putting a fuel filter on it after you do so...
Old Jul 29, 2013 | 01:58 PM
  #10938
dodge dude94
Jiga, that only helps if you can actually GET TO the carb to remove the bowl. lmao
Cheap equipment is a PITA to get the bowl off.
Old Jul 29, 2013 | 03:18 PM
  #10939
dodge dude94
Default Double Post FTW!
Speaking of small engines...I worked on my neighbors mower for a few minutes earlier. She complained that it chugged and had an overall lack of power. She thought it was bad gas. So I took it in and worked on it.
I pulled the air filter and it was nasty, pounded a 1/4 cup of dust out of it. That made it run better.
Next was the spark plug...where I found this:
That is by far and away the worst spark plug I've ever seen. I am amazing the engine was even firing.
Here is the other fun part: the oil is diesel black. Full, but black. A true testament to Honda durability.
I swear by two engines: Honda and Briggs. And the Honda just earned a little more respect from me.
Old Jul 29, 2013 | 03:31 PM
  #10940
Johnn123's Avatar
Johnn123
Honda motors are amazing. Even my dads little civic amazes me with what they can take, he's very bad at maintenance on it and half the time the oil gets left for like a year at a time.... I just changed the oil in a few days ago and less then a liter come out no lie! The way it was running you'da never guessed.
