clunk when putting in reverse
Old Jul 21, 2010 | 08:23 PM
dodge715's Avatar
dodge715
Default clunk when putting in reverse
hi, i have a 1994 dodge ram 1500 slt sort box w/a 5.9 auto 4x4 and it clunks when i put it in reverse and somewhat when i put it in drive. anybody else have this problem? what could it be?
Old Jul 21, 2010 | 09:07 PM
CappinHoff's Avatar
CappinHoff
It's known that it makes the clunking noise. No issues.
Old Jul 21, 2010 | 09:45 PM
Laramie1997's Avatar
Laramie1997
It's normal. Especially on rebuilt transmissions, but the factory build will do it too. Nothing wrong.
Old Jul 21, 2010 | 10:58 PM
jasonw's Avatar
jasonw
Site Moderator
Yup, mine's been doing it since I got her right before 50,000 miles. Factory tranny, no issues. Every Dodge my family has ever owned as done it, never an issue.
Old Jul 22, 2010 | 03:08 AM
CappinHoff's Avatar
CappinHoff
Question is do you hear the same clunk when after you shift to drive and take off? If it does, that isn't normal and may be your u-joints going out. That's what cause my issue with my t-case.
Old Jul 22, 2010 | 10:05 AM
Maxx_Magnum's Avatar
Maxx_Magnum
I've heard that a certain amount of 'clunk' is built into these trannys intentionally... to keep from tearin up the tranny or something, can't really remember why...
Old Jul 22, 2010 | 10:18 AM
Driveline slop. No big deal, so long as it isn't TOO pronounced. Check all or your u-joints, if they are good, block the tires, stick the truck in neutral, and rotate the driveshaft by hand, you should get a SMALL bit of movement, and that's it. If that's ok too, then don't worry about it. It's a four wheel drive.......
