View Poll Results: How would you service the 46RE tranny?
Just change the fluid/filter
0
0%
New fluid, filter, gasket, Deep Tranny Pan
66.67%
Something different, please explain
33.33%
Voters: 3. You may not vote on this poll
46RE tranny service! Maybe upgrades?
Old Aug 23, 2010 | 06:25 PM
notanexit7's Avatar
notanexit7
I'm using the nappa atf right now and I haven't had any problems. Make sure the gasket is the cork kind. I used a rubber one and it didn't seal right. Came out the next morning to find a nice puddle of tranny fluid waiting for me. Although with a different tranny pan you might not have to worry about it.
Old Aug 23, 2010 | 06:29 PM
notanexit7's Avatar
notanexit7
Oh and I don't think adjusting the bands will hurt unless you over adjust them. I think after normal wear they loosen up anyway.
Old Aug 23, 2010 | 06:37 PM
bigslick050's Avatar
bigslick050
So what is the procedure to adjusting the bands? Or should my Haynes repair manual have this info? Srry, don't know diddly about fiddling with the tranny...
Also how many quarts does the 46re auto take stock on '97?
You wouldn't happen to have a part number for a good pan gasket would ya?
Old Aug 23, 2010 | 08:05 PM
notanexit7's Avatar
notanexit7
I have no clue about the band adjustment, all I know is that the guy who did it turned it a good 5 times, it may be different on yours. I bought 7 quarts of atf and he said that was plenty. Only used 5 which led me to believe they didn't flush out the entire system but I was overdue for a tranny service having run 2 years with a non atf+ fluid. The guys at napa gave me a choice of which gasket to get and I went for rubber thinkin it was better than cork. It wasn't. Just ask for a cork one when you buy your fluid. If you don't know how to adjust the tranny bands I wouldn't do it myselft. I've heard about people burning **** up by adjusting them too much thats why I had someone else do it.
Old Jan 3, 2013 | 08:23 PM
Jr. Mechanic's Avatar
Jr. Mechanic
FYI, the hose that PATC sells is just an OEM check valve line with the ball removed. You can do this yourself with a drift punch and a hammer, then a wooden dowl and compressed air to remove the bits. Free, effective, and involves no hose clamps.
Old Jan 3, 2013 | 10:14 PM
gdstock's Avatar
gdstock
heehee....
Old Jan 4, 2013 | 07:44 PM
guzman's Avatar
guzman
Summit racing sells a B&M deep pan (bare aluminum) with new bolts, gasket and filter....has magnetic drain plug and a bung for temperature guage, seems like it was about $139 or so shipped. I have one setting in my garage waiting for a warm spell to install it, nice looking unit.
Old Jan 4, 2013 | 11:56 PM
gdstock's Avatar
gdstock
heeheehee.....
