'98 Dodge Ram 2500 Diesel - AC Stuck on Defrost
Old Aug 22, 2010 | 12:41 PM
k5avj's Avatar
k5avj
Default '98 Dodge Ram 2500 Diesel - AC Stuck on Defrost
Vehicle: '98 Dodge Ram 2500, 5-speed manual, 2 WD Quadcab, diesel, 24-valve, 313,000 miles
Problem: AC coming out of defrost vents when set on AC or any position
Suggestions??? Some sort of vacuum problem???
Thanks,
Lynn
K5AVJ
Old Aug 22, 2010 | 06:03 PM
Yep, vacuum problem. On the passenger side, towards the center, on the firewall, there should be a couple vacuum lines, one disappears back into the cab of the truck, that one supplies vacuum for the vents to operate. On der diesel, I have no clue where it would get its vacuum source from......
Old Aug 23, 2010 | 12:07 AM
k5avj's Avatar
k5avj
Solved my problem today. Found that the vacuum line had fallen down on the exhaust & burned in two. I picked up a short piece of hose from AutoZone...about 4"....and they didn't charge me. I squared off the ends of the burnt hose & used the hose from AZ as a splice by sliding it over the to two ends. Hooray...AC working normal now!
Old Aug 23, 2010 | 09:03 AM
k5avj's Avatar
k5avj
HeyYou - Thanks for your post & help.
Old Aug 23, 2010 | 10:27 AM
Glad ya got it fixed. And, You are welcome.
