mod ideas.
Old Dec 4, 2010 | 03:38 PM
95Erokram's Avatar
95Erokram
Originally Posted by RM_Indy
May want to look a bit closer at his sig
Disabled cat, so either gutted or deleted I would assume
Also its a 95, not 96 or newer so he is OBDI, not OBDII, SCT wont work for him.
B&G or MP PCM only options
Thanks again indy. And yeah. I have a buddy who knows a couple people with the mopar pcm's and would be willing to sell there so thats good news for me and my cat is gutted with pipe through. I dont have emissions here and my muffler makes it not all deafening with the throttle wide open. I will look into the m1 intake, im hearing good stuff about them. Im just curious because in the winter I hit 60 fom a dead stop and some spinning at the line in right under 8 sec. I even have a Stock trans and 3.55 gearing that kills perf. Just dont think mines shot but i will go ahead if its a good power mod . Thanks again. This site has been big help since ive been on it.
Old Dec 4, 2010 | 03:48 PM
95Erokram's Avatar
95Erokram
Thumbs up
Originally Posted by 95RAM360
even if the motor was rebuilt, the plenum is probably still shot...its a factory defect and can only be fixed by a new Hughes FI Intake, M1Intake, or if you buy a plenum kit from Hughes or APS precision.
Well, looked at summit and theyhave m1's. Seems as though i'd have to switch to carburated and thats not gonna happen. Is the hughes FI mean fuel injected. Id like to know more about this plenum situation if possible. Im staying fuel injected. links to these products woud be greatly appreciated! thanks!
Old Dec 4, 2010 | 04:07 PM
This is the M1 manifold. Is a bolt on part. keep in mind, being a single plane manifold, your bottom end grunt is going to suffer for it.
The hughes manifold is dual plane, so, you still lose a bit of bottom end, but, not nearly so much as the M1.
On the bottom of the stock intake, there is a steel plate that seals the bottom of the plenum chamber. From the factory, these were a bad plan, poor quality gaskets, thin steel plate against an aluminum manifold, with bolts that were a tad to long to hold it in place.... A problem just waiting to happen.
Cheapest fix is just replacing the gasket, and using shorter bolts. Best fix is doing that, along with the hughes aluminum plate. Going to the hughes, or M1 intake, completely eliminates the problem.
