New Spyder Halo Headlights - Pics
Old Dec 11, 2010 | 07:13 PM
lukeca's Avatar
lukeca
Default New Spyder Halo Headlights - Pics
Replaced the old yellow headlights with a set of these new Spyder headlights, I think they look really nice, here is some pics if you wanted to see what they look like. Model number is PRO-YD-DR94-HL-AM-C
Oh and a tip, check your factory wiring compared to the headlights, the headlights seem to be wired for a newer model, on my 95 I had to switch the position of the ground and high beams to match the factory wiring.
Old Dec 11, 2010 | 07:24 PM
bardram's Avatar
bardram
Im usually not a big fan of lights like that, I think they look too "ricer" for a truck, but those look really nice! And I definitely like that paint job.
Old Dec 12, 2010 | 08:14 AM
Sheriff420's Avatar
Sheriff420
That first picture is pretty awesome.
How do you like the light pattern they put out?
I'm digging the paint job too, is the black only on the hood?
Old Dec 12, 2010 | 09:10 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Where did you buy these lights?
Old Dec 12, 2010 | 12:42 PM
lukeca's Avatar
lukeca
Thanks guys,
I like the light pattern, I don't really notice much difference from the stock lights, maybe a little brighter since the plastic is clear now and not all yellow and cloudy. The black goes all along the side of the truck, and it's along the bottom too, with the red in the middle. They are not HID lights or anything, just standard halogen.
I got the lights from autoanything.com, on black friday they had 15% off everything and free shipping. Ordered some rotors and pads for my wife's car too, so the 15% off worked out pretty good for me. Actually they still have the 15% off right now...
Old Dec 12, 2010 | 11:51 PM
joshsbetterhalf's Avatar
joshsbetterhalf
Dang. Those look amazing. I've got some lens restorer I'm gonna try first but if it doesn't work, I know what I'm getting!
Old Dec 13, 2010 | 12:09 AM
redheadhunter21's Avatar
redheadhunter21
Looks good...did you wire the halo's into the parking lights
Old Dec 13, 2010 | 08:44 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by lukeca
Thanks guys,
Cool beans. How well do they work at night? Are the instructions clear and precise? These might be a worthy upgrade as I'm planning to redo my truck from front to back.
Old Dec 13, 2010 | 11:42 AM
lukeca's Avatar
lukeca
Yep I wired the halo's into the parking lights
I was surprised to find that they actually come with no instructions, spyder has a youtube channel where they have some installation videos, so I watched the one they had for dodge, but it was a 3rd gen, but then I found another youtube video of someone replacing the lights on a 2nd gen.
I ran into three main issues, first I got the old headlight out without removing the bumper, but I couldn't get the new headlight in, but instead of removing the whole bumper (I didn't know how heavy it was and I was by myself), I was able to just remove the black plastic trim piece and that was enough room to get the new headlight in.
Second, at first the brights wouldn't work and the brights indicator was always on. In the connector from the headlights I just had to change the position of the blue and black wires, I could see the way they were wired didn't match the truck. Inside the harness for the headlights you can just push down on this little tab on the pin and it will slide out of the harness so it is easy to switch them around.
Third, when I first put the headlights in they looked really weird and were sticking out the sides (actually the second two pics are from before I adjusted them), but I found that there are two adjustment screws, one for vertical and one for horizontal. So you can adjust the angle of the headlights to get them pointed correctly and to make them fit properly.
Old Dec 13, 2010 | 12:08 PM
TheBigRedOne's Avatar
TheBigRedOne
You should get us some output shots up against a wall, so we can see the cutoff. Looks good.
