My early review of the Hughes FI Air-Gap Manifold...
Old Jan 2, 2011 | 03:41 PM
  #41
Caution's Avatar
Caution
We have the same gearing 4.56. Thats why i asked. Same as the kegger for the low end. I just may keep the kegger and put 600 towards some other go-fast parts.
Old Jan 2, 2011 | 10:48 PM
  #42
CPTAFW163's Avatar
CPTAFW163
Hey Drew,
Any chance that Bruce sent you these:
http://www.fiveomotorsport.com/fuel-...rs/?itemid=116
PN: Bosch 0280156028
He was supposed to send these:
http://www.fiveomotorsport.com/fuel-...rs/?itemid=113
PN: Bosch XF2E
The first ones are 24# injectors for the V10. He might have mixed them up. Check the PN.
Old Jan 3, 2011 | 07:58 AM
  #43
drewactual's Avatar
drewactual
he sent me the second ones.. the pic makes the lower o-rings look aqua, but they are in fact green as green can be.. but those are definitely the ones he sent.
After HemiFever hooked me up with a tune that cuts back, the truck doesn't have a single issue. I can't wait to see what the gauge tells me when I get it on there. I bet he's pretty close. I'm not going deep into the throttle until I can get that reading..
Old Jan 3, 2011 | 08:01 AM
  #44
drewactual's Avatar
drewactual
I don't know that I gained any low end, but I'm sure I didn't lose any..
the biggest motivation for me to do this mod was the lack of plenum pan/gasket.. I will never have to worry about it again- and that is a nice peace of mind.. I should have taken a pic, but I figured a mod would have to remove it if I did, but on the valley cover of the intake, and whilst I had my dremmel in hand- I made a little inscription..
that inscription reads: $#&$ a Plenum Gasket!!
Old Jan 3, 2011 | 03:14 PM
  #45
Sheriff420's Avatar
Sheriff420
Flooring it from a stop felt the same to me down low with stock gears (airgap vs. kegger).
Lug...1000 rpm, lug 1300 rpm, lug 1500 rpm, lug 1700 rpm, perk up 2000 rpm, perk up a little more 2300 rpm, wake up 2500 rpm, scream 3000 rpm.....
Old Jan 4, 2011 | 12:51 AM
  #46
lastrights's Avatar
lastrights
do you think the airgap would be a good buy before the gears ? i have the 600 to bun now but dont have 2300 anytime soon. should i just save for the gearing and still keep the kegger ?
Old Jan 4, 2011 | 02:38 AM
  #47
Sheriff420's Avatar
Sheriff420
I don't have any complaints about it and I would buy it again.
If you want to keep saving for gears then you could just mod the keg.
Old Jan 4, 2011 | 08:30 PM
  #48
lastrights's Avatar
lastrights
lol im just going to do the airgap 1st just because i think my plenum is bad and my rear end is still in good shape . and people seem to rave about it. going to do a timing chain as well
Old Jan 5, 2011 | 06:04 PM
  #49
lastrights's Avatar
lastrights
what did you guys put the IAT into if you dont have a hose and have the 14x3 ?
Old Jan 5, 2011 | 06:35 PM
  #50
drewactual's Avatar
drewactual
stick it on the bottom of the hat.. between the inner filter surface and the TB.. it's harness wiring will reach a decent distance.. that there wee lil trick will net you a pony or two in and by itself.
