Yup.... here we go again. (Transmission)
Old Mar 14, 2011 | 10:46 PM
  #21
LegendKiller89's Avatar
LegendKiller89
So by putting in a governor pressure sensor I should fix my problem?
Old Mar 14, 2011 | 11:04 PM
  #22
If there isn't some mechanical reason for the low pressures, yep. Should fix it.
Old Mar 14, 2011 | 11:05 PM
  #23
LegendKiller89
Trans guy said it wasn't anything mechanical. God dude you have no idea, how much I hope that is it.
Old Mar 14, 2011 | 11:15 PM
  #24
Right around 2000 dollars worth?
Old Mar 15, 2011 | 11:24 PM
  #25
LegendKiller89
Could the speed sensor in the trans be bad???? I am just throwing this out there, no codes but I have read that this could be the problem. From what I have read speed sensors can cause the same problems I am having.
Old Mar 16, 2011 | 11:35 AM
  #26
If your speedometer works, the speed sensor is doing its job.
Old Mar 20, 2011 | 01:11 AM
  #27
LegendKiller89
Truck is Fixed!
Bought the Governor Pressure Sensor, dropped the pan tonight and sitting on the magnet was my forward gear band anchor. That would explain ALOT! So I dropped the valve body and put the anchor back in. Torqued the band to its spec, put the sensor in, re-installed the valve body up, got all my other stuff hooked up, bolted on. Filled it with fluid took it down the road.
At first the truck would takeoff in 2nd... then go through all the gears. But I disconnected my battery after I brought in the shop before I started working on the truck. But after a few stop/go the computer must have re-learned itself enough... now the truck shifts 1-2 2-3 3-4 OD. Everything is cool again.
Old Mar 20, 2011 | 01:55 AM
  #28
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by LegendKiller89
Truck is Fixed!
Glad to know it! Good Job.
Old Mar 20, 2011 | 11:57 AM
  #29
LegendKiller89
Thanks man.
Old Mar 23, 2011 | 05:18 PM
  #30
supra300zx's Avatar
supra300zx
My brother is having this same problem except he starts out in 2nd gear instead of 1st but he can manually shift it into 1st gear to get going...
