Thoughts on these gear prices...
Old Mar 1, 2011 | 04:53 PM
Silver_Dodge's Avatar
Silver_Dodge
Originally Posted by LegendKiller89
That's just parts.
How did you like that Auburn unit Silver? Kind of heard bad stuff about them. Do these LSD units such as Auburn and Detroit hold up to 35's??
I had a problem with the first Auburn unit I had. I had only run 33" tires with it, but after about 35k miles, the retainer clip that holds the springs in place broke. Luckily I caught it before it did any damage to anything else in the diff. Turns out, that first LSD unit I had came from a set of parts that had a known defect that Auburn had seen in some units sold about the time I bought mine (AG1505 is the part# of the one that broke). They had since replaced that design with a new one, and it is part# AG542070. The new unit is said to be much better, and supposedly has no issues like my first one did. So that's the one I have in now with my 35's/4.56's, and it has been fine so far. Auburn confirmed to me that their units are rated to up to 36" tires.
Other then this issue, I have been very happy with it. Auburn actually has a great reputation for building a good limited slip, and I would still recommend it to someone. the only other one I think is worth a look is the Detroit Truetrac. It is a gear driven limited slip, which is supposed to be stronger then cone and clutch types, but i'm not certain if it is rated for 35" tires or not.
Old Mar 2, 2011 | 02:38 AM
Sheriff420's Avatar
Sheriff420
1700 is too much.
I paid $1600 at completeoffroad.com for gears/install kits/setup bearings (same price as an open carrier for the front) and detroit truetracs (yes that's plural).
It's all Yukon too.
If I had just gotten one truetrac for the rear then it would have been $1100.
Old Mar 2, 2011 | 03:48 AM
ColoradoRamLover's Avatar
ColoradoRamLover
so just to put 35's on my truck, I would have to upgrade the gears? I take it my 4.10s wouldnt like 35's too much.
Old Mar 2, 2011 | 04:34 AM
Sheriff420's Avatar
Sheriff420
I imagine they would like them as much as 3.55 gears like 285/70/17 tires.
Old Mar 2, 2011 | 02:43 PM
LegendKiller89's Avatar
LegendKiller89
Thanks for the info Silver.
I've read alot of threads of yours from 4:10 vs 4:56 to locker vs LSD, all have had great info, learned alot. But here's a question for you - if you could do it all over again would you go Locker or LSD?
Completeoffroad won't respond to emails. Good price though. Looked on PORC yesterday and could get everything for $1,200. (PORC install kits)
Colorado:
Would your 4:10's like 35's? Meh. It's not going to have the same get up and go as 4:56 but if you don't wheel your truck, and its just a DD then 4:10 would be ok. But if you like the loud pedal... even half as much as me, you will wish you had 4:56.
Heck dude I got a set of 4:10's I bought from a chap, but decided its worth the extra money for the right setup. Not something I'm going to look back at and say oh wish I would've went for 4:10.
Old Mar 2, 2011 | 03:40 PM
Silver_Dodge
If I could do it again, i'd do the same, and that's because of the way I use my truck. If someone made an air/electric locker for the 9.25, then yes I would have gone with the locker no question. But since I don't want a full time locker (which is all you can get in the 9.25), the LSD is the way I went.
I ran 35's with my 4.10's originally, and based on the fact that I now have 4.56's, I think you know how I felt about it.
If you want your truck to lose performance, then go ahead an install 35's with your 4.10's. They will work, but it will negatively impact your trucks performance.
Old Mar 2, 2011 | 04:44 PM
LegendKiller89
Like I said it was one of your 4:56 thread's that changed my mind.
