Any tricks for straitening the bed behind cab?
Old Mar 10, 2011 | 11:16 PM
hbarker's Avatar
hbarker
Default Any tricks for straitening the bed behind cab?
You guys know any tricks for straitening the bed behind cab of the truck??
Mine was smashed in enough to rub the cab on occasion when I bought it.
I managed to use a 2x4 to get it off the cab , but would like to straiten it out.
Thanks
Even thought about taking it off and adding a light weight flat bed if I could find one.
Old Mar 11, 2011 | 12:59 AM
Sheriff420's Avatar
Sheriff420
Mine is bowed toward the cab too from a hard stop with a Chevy torque converter in the bed that wasn't strapped down. I thought I got rear ended until I saw the transmission fluid on the rear window. Mine isn't touching the cab though.
I would say take the bed off and lay a 4x4 on the bend then get happy with a sledge hammer. Is the bend on the front of the bed or on the outside of it? I am thinking it's on the front from something sliding in the bed.
Old Mar 11, 2011 | 09:14 AM
New 96's Avatar
New 96
I would find a nice size tree back up to it wrap a chain around it and hook on a come a long > on either side of the creased area of the back of the bed drill thru with a eye bolt on each side using large washer for strength. put a chain between the 2 eye bolts and the attch the come a long. then start cranking on the come a long slowly till it has pulled the bed away from the cab. Just a thought
Old Mar 11, 2011 | 01:29 PM
hbarker's Avatar
hbarker
hmmm, Yep fer sure on the front,,
That *** along sound like a good Ideer ,,
Old Mar 11, 2011 | 03:44 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Mine gets bent there from hauling my wheeler around with a tire wedged in front of it to keep it off the window, but I can just grab it and yank it back straight. A former member here (Miami_Son) and maybe some others have welded or bolted some metal across the front of the box to stiffen it up, this is what I plan to do with mine...
Old Mar 11, 2011 | 06:45 PM
hbarker's Avatar
hbarker
Say maxx,,
I like that tread pattern on those uniroyals ,, where you get em?
Old Mar 11, 2011 | 07:07 PM
Maxx_Magnum
Thanks hb, but those are actually BF Goodrich A/T's, got em of kijiji for half price with only 1000kms on em!
Old Mar 16, 2011 | 10:53 AM
dipsherry's Avatar
dipsherry
mine was bent pretty bad after the locking of the brakes with a 4cyl Pontiac in the bed i used a *** a long and a tree to straighten mine out. a lil redneck but it worked
Old Mar 16, 2011 | 02:47 PM
Maxx_Magnum
You shouldn't be carrying Pontiacs around with ya
Old Mar 16, 2011 | 03:56 PM
hbarker's Avatar
hbarker
I would tel you guys what Pontiac stands for,, but will with hold my racial comments
