Differential fluid type?
Old Aug 17, 2011 | 03:48 AM
CharlieEscobar's Avatar
CharlieEscobar
Default Differential fluid type?
Hey guys, I almost made a catastrophic mistake with my Durango's diff fluid. Now I'm concerned about my Ram.
I've some threads on this forum for rear diff fluids, but I don't know what rear end I have and whether I need the friction additive.
I have a '96 1500 Ram, 2wd, 5.9, auto
Can someone help? Thanks guys.
Old Aug 17, 2011 | 06:21 AM
PurplDodge's Avatar
PurplDodge
Originally Posted by PurplDodge/Factory Service Manual
Transfer Case Fluid - NV231HD and NV241:
ATF+4. The reason it doesnt take gear fluid is because if the seal between the transmission and transfer case starts to leak, the transmission wouldnt get contaminated by gear fluid, but instead ATF+4.
Front Axle Gear Fluid - Dana 44 and Dana 60:
SAE 75W-140 Synthetic gear fluid that meets MIL-L-2105C and API GL 5 Specifications
Nearly everyone who makes engine oil has a line of 75W-140.
Rear Axle Gear Fluid - Chrysler 9.25, Dana 60, 70, and 80:
80W-90 gear lubricant in normal conditions
75W-140 Synthetic gear lubricant for heavy duty or trailer towing intended uses.
Both must meet same specifications as above
I really wouldnt worry about what fluid you put in it, the axle would go a million miles with grease in it.
Old Aug 17, 2011 | 09:16 PM
dhvaughan's Avatar
dhvaughan
look on the rear axle tube, driver side.
you might be able to find the original part number sticker, which will say something like "chrysler 9.25" OPEN or LIMITED SLIP.
if you don't find it, look in the glove box (some years) or under the hood sticker (other years) for those same words.
failing that, you can email dodge for a Build Sheet.
if you can't tell whether you have LSD or not, then go ahead and add the friction modifier anyway. its not overly expensive, $5-10.
as far as the gear oil itself, anything with GL5 rating is fine. walmart sells 85W90 and 85W140 in the gallon jug for about $12.
another test for LSD is jack up one rear wheel and try to turn it. if it easily turns, its likely not lsd, at least not one that works.
Old Aug 18, 2011 | 02:50 AM
CharlieEscobar
Ok cool thx guys. I'll see if I can find anything on the truck. I've seen somewhere on here about getting a build sheet- sticky thread I think. I never looked at it but didn't know you could do it by email.
Old Aug 18, 2011 | 06:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.dodge.com/wccsapp/univers...ull&category=U
Old Aug 21, 2011 | 10:50 PM
CharlieEscobar
Ok guys, i managed to get a build sheet. This is what it says about the rear end:
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
In the hood area, I found the sticker with a few specs. It said Chrysler 9.25.
The "LD" has me stumped. Still no clue if it needs LS additive
Old Aug 21, 2011 | 10:57 PM
aim4squirrels's Avatar
aim4squirrels
LD is light duty.
Any relation to Pablo?
Light Duty. It's a half ton truck.
Old Aug 21, 2011 | 10:58 PM
PurplDodge's Avatar
PurplDodge
Light duty? It would say if you had a limited slip diff.
Old Aug 21, 2011 | 10:59 PM
aim4squirrels
too slow, biznatches. LOL
