End of the line...
#22
Matt: I'm with others.. you're past the point of return- you're too deep in all of that to bail now.. get another second gen from someone fed up with burning oil and transmissions that won't downshift to first gear.. and buy it.. you'll be much MUCH happier in the end.
#23
#26
The neutral safety switch is the same for both. So he's a moron. However, the Gov pressure sensor/transducer and the TCC/OD solenoid assembly is what's different. And can be swapped without a problem.
#27
#28
#29
okay, i am no longer a dodge guy
i bought a 2003 jetta with a 1.8 turbo w/ 5 speed. its definitley fun to drive. going from the ram to this, and lets just say shes no slouch. ive driven 60 miles and the gas gauge hasnt moved. entering onto the interstate is now, a refreshing experience haha!
i have yet to find a knowledgeable vw forum, and aside from VDUB himself, i know this is not a vw forum, but i do have a few questions!
the car has a turbo back exhaust w/ cat delete, the post o2 is recessed with non foulers, it has a larger intercooler pipe, cold air intake, and stage 2 clutch and light weight flywheel, recirc. bov, and of course 4wheel disc brakes with an awesome abs system! it also has an automatic "locker" that functions much like an lsd, it isnt a true locker. the PO is a mechanic at a local imports shop, so i know this stuff was installed correctly. he is also doing the timing BELT (hey! wheres the double roller?! hehe) water pump, thermostat, and serpentine belt as well as a few other maintinance procedures this weekend... free of charge!
my issue is a cel for lean fuel on bank one and idle air control system RPM higher than expected. the idle is indeed high, around 800- 1k, and it varies. its not erratic but it isnt exactly steady
the issue is only noticeable at idle. when the a/c is first turned on, it may shudder for a second and then it rebounds to its usual idle.
things that have been checked are: maf replaced twice, checked for vac leaks and intake manifold gasket replaced, fuel pressure check, fuel filter change, spark plug change.
i beleive the two codes are related, but any ideas on what this could be? should i replace the iac?
#30
