Ideas to secure 55 Gal drum lying down.
So this winter I want to have a decent amount of weight over the rear axle to make driving as painless as possible in the snow/inclement weather. I have a 55 Gallon heavy duty PVC drum that I plan of filling 3/4 the way up with water. I need to lay it flat because I need the bed cover rolled down (closed/covered). This will be used in conjunction with sandbags. I have five 5000lbs ratchet straps. Ideas on how to tie this sucker down good?
You don't want it only partially full. That gives the water room to move, and can make cornering rather exciting when the water all shifts, then sloshes....... You want to concentrate the weight over the rear axle, so, build a wood frame out of 2x4's that the barrel will sit in, and not be able to roll of it's own free will. (extend the front to back legs a good foot or so past the sides that actually prevent the barrel from rolling.) Put some eye bolts into those, and use the straps to secure the barrel to the framing.
Is the bed tall enough for what you have in mind?
I have a barrel and a few sand bags already, save me some $$$
i've never put weight in the rear of my ram before.... do you guys really have that much trouble with snow and ice? when it snows i rarely use 4wd i probly use it 3-4 times during winter and its either to pull someone out or if i'm going up a logging road
Trending Topics
If I get into a wreck, the barrel is the least of my worries. As tall as my truck is, I'd be afraid for the person I hit. It's a lawsuit with 4 wheels. I give tractor trailer size room to cars in front of me. I'm always scared that someone will rear-end me at high speed because when I park my other vehicle behind the truck, my trailer hitch is almost eye level. I working on a custom bumper to lower the height in that event.
