Firewall Access Hole???
Hey Ladies,
I'm trying to find another hole to access thru the firewall. I looked from inside and can't use the one that the hood cable goes through (rear aux light and amp lines). So I found a hole with rubber grommet about 1" diameter to the right.
Here is a picture from the engine bay side. It the diamond shaped rubber on the left. Is this readily available?
If so, just pierce hole so that the rubber grabs around wires?
Purpose is to run some wires into a switch. Later, an additional small diameter air line for pressure gauge. I presume this would be the access for other accessories like POD gauges?
Thanks for any input or suggestions.
Thanks HeyYou, that did it!
Next question regarding the lovely bundle of wires on the steering column.
I found from here: http://alarmsellout.com/support/diag...01992-2005.pdf
Ignition Wire color is Dark Blue
I can't determine if there is a wire for "Dash Illumination". Would that correspond to Accessory Wire?
Thanks again for any input.
Hmmmm, according to this looks like Illumination is Black/Yellow
http://en.allexperts.com/q/Car-Stere...allation-2.htm
I heart electrical, hence I made it last...just as the sunlight went out. TBC tomorrow.
