Can I fit 37" dick cepek on my truck? PLEASE HELP!
Old Dec 11, 2011 | 05:54 PM
  #31
Wombat Ranger's Avatar
Wombat Ranger
Why do you wish you didn't get the off road edition?
Old Dec 11, 2011 | 07:10 PM
  #32
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by simonsdodge94
So then a 5" would only be a 3"? Thank god I returned my 3" lift and got the 5" then I would only have a 1" suspension. So I think I might add 2" coil spacers in the front so that the front sits 8" and then add maybe 1-2 leaf springs on the rear if it doesnt level out
Wish I didnt get a off road dodge. Oh well. I'll just add 2" coil spacers so that I get the lift I want. Some dudes told me that they have a off road dodge and they added a 5" lift and said it netted out to 4.5" of lift. Will mine do that and how can I tell
I only read the last 2 pages here. You don't ever put coil spacers on a suspension lift. The warranty on the lift would be voided immediately, moreover, its not designed for such hack moves like that. Sorry if that is harsh, but wouldn't want some to spend some coin on a SL only to have it fail.
Regardless of the O/R model, any suspension lift removes the O/R lift. The net lift will always reduce a bit due to the springs settling out and other truck to truck variables. This is the same for a stock truck getting a SL.
You will have plenty of room for 37" tires with a 5" SL and 3" BL. You're only real issue, I think, will be rubbing if you don't have the right backspacing.
Old Dec 11, 2011 | 07:58 PM
  #33
simonsdodge94's Avatar
simonsdodge94
Cause the off roads takes 2" of suspenaion off a kit. If I were to have a regular non off road dodge then I would have 5" suspension instead of 3" suspension even though it's a 5" lift kit
Old Dec 11, 2011 | 08:01 PM
  #34
simonsdodge94
Well I have the 5" BDS Lift. So I should be getting 4.5" of suspension for a 5" lift? Will coil spacers cancel the warranty on a BDS lift? What about a leveling kit? Will that void the warranty? And in terms of making the truck higher which one will lift the truck higher? Coil spacers or a leveling kit?
Old Dec 11, 2011 | 08:53 PM
  #35
Wh1t3NuKle's Avatar
Wh1t3NuKle
I hope you came to understand after reading my reply (in addition to HeyYou previously) that your response above makes no sense.
You ran out of your limit on questions, ergo forget about the tires and just work on this thing.
Good luck!
Old Dec 11, 2011 | 10:20 PM
  #36
Wombat Ranger
^^^^BAAAAHHHAAAAhahaha!!!!!! +1
Old Dec 12, 2011 | 02:56 AM
  #37
smcandrew08's Avatar
smcandrew08
Are you planning on using the stock d44 and d60 axles with these 37s?
Old Dec 12, 2011 | 03:13 AM
  #38
biggreen2500's Avatar
biggreen2500
whats wrong with Dana 60s. Mr 1500
Old Dec 12, 2011 | 04:03 AM
  #39
smcandrew08
Nothing is wrong with d60s, I wish I had a 2500 swap for my truck. But from everything I have read you dont want to go any bigger then 35s with stock 1500 axles. Im not sure if the off road edition has a d44 or not but I dont think. When upgrading to big tires brakes come into play and 37s on a stock 1500 kinda seems like its pushing it...
Old Dec 12, 2011 | 11:51 AM
  #40
simonsdodge94
I'm pretty sure I can put 37s on with stock Dana's. But we'll see
