Giving my ram a little lift
Old Dec 25, 2011 | 07:23 PM
  #21
stewie01's Avatar
stewie01
What brand spacer did you buy? I'm fixin to order a Rough Country 2.5" spacer for $99. Is your front end even with the rear or a little +/-?
Old Dec 26, 2011 | 10:31 AM
  #22
tweav88's Avatar
tweav88
Okay, well if yours was 4wd id say dont order from rough country, i got a hell bent steel one(hellbentsteel.com) 2" was $65, and 2.5" was $80, free shipping, and they are made out of steel, not some plastic like some ive seen,
i ordered helper springs as well they just havent gotten here yet, and im glad i did, because to me it looks like the front it just a little higher now, but def looks a lot better.
Since yours is 2wd, i dont know how level your truck would sit, and i dont think HBS offers leveling kits for the 2wd, but id probably not go with a 2.5 cuz your truck is gonna be sitting nose high.
Old Dec 26, 2011 | 12:44 PM
  #23
stewie01's Avatar
stewie01
Well neither Hell Bent Steel or Rough Country advertise coil spring spacer's for a 2wd.
So I guess I'll be a guinea pig. Probably will get one from hell bent steel though, their stuff is cheaper.
Old Dec 26, 2011 | 01:25 PM
  #24
merc225hp's Avatar
merc225hp
You could try a set of 2wd 2500 diesel springs rockauto has them. I am not sure what they would do for lift number wise. See if you can find the specs on both sets of springs and cross reference them. Inside dia is what matters to make sure they fit in the spring cups/seats.
Old Dec 26, 2011 | 02:03 PM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
What about springs from an older model sst v10?
edit: or did they only come with 360's?
Old Dec 26, 2011 | 02:15 PM
  #26
merc225hp's Avatar
merc225hp
SST/Indy trucks came with the 360. I do remember some flavor of 2nd gen with a v10; a concept truck I think.
Old Dec 26, 2011 | 02:19 PM
  #27
stewie01's Avatar
stewie01
This is the first 4 springs for '01 2500 Diesel
RAYBESTOS Part # 5851208 Professional Grade; Sold in Pairs -- Inside Diameter=4.03" Wire Diameter=.937" Free Height=12.97" Load height=11"
RWD; Heavy Duty; Front; Extended Cab Pickup; 4 door
$77.79
Add Part
RAYBESTOS Part # 5851207 Professional Grade; Sold in Pairs -- Inside Diameter=4.03" Wire Diameter=.937" Free Height=12.66" Driver Side/12.56" Pass. Side Load height=N/A
RWD; Front; Extended Cab Pickup; Standard Cab Pickup
$77.79
Add Part
RAYBESTOS Part # 5871135 Professional Grade; Sold in Pairs -- Wire Diameter=.843" Free Height=18.09" Load height=16"
4WD; Front; Extended Cab Pickup; 4 door
$89.89
Add Part
RAYBESTOS Part # 5871134 Professional Grade; Sold in Pairs -- Wire Diameter=.828" Free Height=17.78" Load height=16"
4WD; Front; Standard Cab Pickup; 2 door
There isn't any similar information for the '01 1500 gas springs except either constant or variable.
I emailed support at hellbentsteel asked them about 2wd springs.
The 4x4's are solid front axle right? And the 2wd's are independent front suspension, but how much difference in the coil spring housing can there be?
Old Dec 26, 2011 | 02:20 PM
  #28
zman17's Avatar
zman17
Yup, you are right. Did some research. The truck with the v10 never went into production back then.
Old Dec 29, 2011 | 04:01 AM
  #29
97tn4x4's Avatar
97tn4x4
Rough Country does make a 2'" level for the 2wds cause ive installed a set on a truck before. The back was just a tad lower than the front. He had a 2wd with a 3" body and a 2" level on 35's.
Old Dec 29, 2011 | 05:10 AM
  #30
stewie01's Avatar
stewie01
I'll be sure to check it out again...
