Ordered Parts
Old Dec 28, 2011 | 03:45 PM
stewie01's Avatar
stewie01
Default Ordered Parts
Well ordered the Hughes Plenum Kit last night, also ordered a Double Roller Timing Set from Rockauto, used the discount code
Stopped by the dealer and ordered intake manifold bolts, $1.45 each.
Also got a new set of FelPro Valve Cover gasket's and some red engine enamel, yup, they're getting painted after it's all said and done.
Should be running like a top pretty soon! (not that it runs bad now...)
Spent way too much on tires, exhaust may have to wait a little bit...
Anything else I should get while I'm at it?
Old Dec 28, 2011 | 04:05 PM
FireDodge's Avatar
FireDodge
If you haven't done plugs, wires, rotor and cap in awhile now would be the perfect time to do so because the cap and rotor are a PITA to get to with the intake on.
Old Dec 28, 2011 | 04:07 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^agreed with the above.
Couple other items also, if you haven't done them recently (sorry I don't recall for you stewie), new O2 sensors and pcv valve and grommets. I think these are good things to replace at the same time.
Old Dec 28, 2011 | 04:19 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
also, get plenty of penetrating spray and seafoam BEFORE the dis-assembly.
Another thought, replace o-rings on your injectors. Just in case you do happen to pull them. hahah
Old Dec 28, 2011 | 04:43 PM
stewie01's Avatar
stewie01
I hope to get by leaving the fuel rail in and using it as a handle But it wouldn't be a bad idea to have replacement's
Definitely doing some SeaFoam.
Old Dec 28, 2011 | 04:47 PM
stewie01's Avatar
stewie01
Can't believe I forget about those! Yup, those should be getting replaced too.
Old Dec 28, 2011 | 06:26 PM
lastrights's Avatar
lastrights
New Coolent bypass hose and tune up parts and oil change after
Old Dec 28, 2011 | 06:36 PM
chadhager03's Avatar
chadhager03
Fuel line disconnect tool and a inch pound torque wrench
Old Dec 28, 2011 | 07:05 PM
stewie01's Avatar
stewie01
Got em both
Old Dec 28, 2011 | 07:31 PM
gdstock's Avatar
gdstock
Originally Posted by stewie01
Well .......Anything else I should get while I'm at it?
Silly boy!!!!!!!!!!!! You gotta get beer!!!!!!!!
