Diesel question.
Old Jan 4, 2012 | 10:16 PM
SweetTooth's Avatar
SweetTooth
Default Diesel question.
Do diesel engines get a better mileage than normal gas trucks?
I'm thinking of saving for a new truck here shortly. I love dodges, but mine just isn't cutting it.. 250 miles per tank full city / street.
Gas for diesel is like 3.70+ but it'll be worth it if they last longer.
I'd like to hear your input.
Old Jan 4, 2012 | 10:49 PM
redheadhunter21's Avatar
redheadhunter21
Yes most of the time....and while towing there is no comparison
Old Jan 4, 2012 | 11:06 PM
Gerehead8's Avatar
Gerehead8
Diesel has 30% more energy per gallon than gasoline and diesels often utilize direct injection and turbocharging both of which increase efficiency. So yes diesel do get better mileage than gasoline engines.
Old Jan 5, 2012 | 12:55 AM
FireDodge's Avatar
FireDodge
A buddy of mine has a 95 Cummins and back when it was pretty much stock, he would get 18-20 in city and 25+ on the highway. Now that he's done some fuel mods and a lot bigger turbo he gets between 8 and 12 mpgs. So as long as you don't mod it horribly , yes it would probably get you around better.
Old Jan 5, 2012 | 01:17 AM
BackwoodsRam's Avatar
BackwoodsRam
A buddy of mine had an 04 Cummins on 35's and could get 30 mpg's on the highway
Old Jan 5, 2012 | 08:14 AM
kejobe's Avatar
kejobe
My uncle has a 3500 4wd, '95 I think, says he gets about 20mpg.
Old Jan 5, 2012 | 10:18 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
....and it will follow for moar.
Old Jan 5, 2012 | 07:44 PM
Novarider's Avatar
Novarider
You will pay quite a bit more for the truck if it's a diesel. One benefit of that is MOST people that own a diesel take very good care of them
Old Jan 5, 2012 | 08:19 PM
Trouble is, all that additional money you spend to get the oil burner, would buy a lot of gas....... not to mention increased maintenance costs, etc. Unless you tow/haul, or drive a LOT of miles, you will come out further ahead with a gas engine.
Old Jan 5, 2012 | 08:39 PM
crazzywolfie's Avatar
crazzywolfie
i have read that a 12 valve cummins with a lock up torque converter and overdrive could most likely out mpg a lot of the newer diesels but are expensive to fix
