Lucked out on a HP Dana 60 front
Old Mar 4, 2012 | 11:09 AM
  #61
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Front to be paired with a 10.25 Sterling
Yeah, I'm going to have ford axles under the dodge! Sterling is already 35 spline axles shafts and they are plentiful. Also found a mod for the VSS. These are axles are plentiful. Only issue is the carrier design is weak for 38" and larger. This is a much cheaper alternative.
Fix for that is chucking the whole carrier and use the ARB locker.
Old Mar 4, 2012 | 02:57 PM
  #62
Wombat Ranger's Avatar
Wombat Ranger
I am excited to see this happen!!!
Old Mar 4, 2012 | 09:54 PM
  #63
newman1367's Avatar
newman1367
Could you please point me in the direction of the VSS mod? Also weld the axle tubes to the centersection on that axle! And have you looked for a set of 5.13's for the sterling?
Old Mar 5, 2012 | 01:01 AM
  #64
Wh1t3NuKle's Avatar
Wh1t3NuKle
Thanks dude. Honestly I'm MOAR excited for you to get that transfer case and other assorted improvements installed and roaring!!
I send it to ya big guy.
I must not have come across the same issues as you about the centersection... lol Sounds interesting.
Yes I've looked at 5.13s from Yukon, like this.
Is there something about them that you're asking?
Old Mar 5, 2012 | 06:56 AM
  #65
newman1367's Avatar
newman1367
Last time I checked I couldn't find 5.13's for the sterling. But I didn't look too hard. I didn't think it had a lot of aftermarket support.
Old Mar 6, 2012 | 02:13 AM
  #66
Wh1t3NuKle's Avatar
Wh1t3NuKle
They have lockers, gears, and disk brake kits, among other things.
Old May 12, 2012 | 01:29 AM
  #67
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default The front axle handler
I have to double fist to hold just one of them.
(post 1,400)
Old May 12, 2012 | 02:54 AM
  #68
Wombat Ranger
Those are some manly shocks!
Old May 13, 2012 | 02:23 AM
  #69
johnnyjaws98's Avatar
johnnyjaws98
rockwells !!!
Old May 15, 2012 | 12:46 AM
  #70
mj23polaris's Avatar
mj23polaris
(post 1,400)
i like.....
look at WFO concepts they make a truss for your 60
http://www.wfoconcepts.com/cr/Dana-6...sses/3466/3468
