My Truck's Progress Thread
Old Feb 21, 2012 | 04:55 PM
  #61
Aside from them being missing on my truck? No... not really......
Old Feb 21, 2012 | 05:07 PM
  #62
Steffenaj14's Avatar
Steffenaj14
lol yeah mine are getting there.. any aftermarket ones that don't need to be cut and made.. i want ones that come pre fit.
Old Feb 21, 2012 | 06:35 PM
  #63
LMC Truck sells them, along with other sheet metal places.
Old Feb 24, 2012 | 09:39 AM
  #64
Steffenaj14
well i've seen the ones that you have to remove the door panel along with all the rust then weld in a new one. i'm just talking about the running boards that you can put overtop of everything
Old Feb 24, 2012 | 10:12 AM
  #65
That won't stop things from rusting further though, and eventually, the cab will simply fall apart. Granted, bodywork is friggin' expensive....... and for me, at least, It most certainly is NOT worth what it would cost to have someone else fix it for me. (unless, of course, I won the lottery......)
Old Feb 24, 2012 | 02:27 PM
  #66
Steffenaj14
i'm the same way. i got quoted at almost 4 grand on body work to get it all fixed. im not going to put that much into it. some running boards to make it look better are all i need. i will sand it out and fix it the best i can to make the rusting stop as much as i can then i will put running boards over it so nobody can see cause i sure as hell can't blend that paint and make it look smooth and all that
