egr delete&vac lines question
Old Feb 27, 2012 | 01:28 PM
Wombat Ranger's Avatar
Wombat Ranger
When I tore through mine for the first time the black plastic thing was toasted, and I just went to the local JY and grabbed that and whatever else around it that i needed.
Could you possibly just stick rubber hoses over the ends of the plastic line (the burnt parts)?
The other one is rubber so that's a no brainer.
Originally Posted by cutthroatxxx
What are you talking about?You been sniffing markers?Im asking where the vacuum lines go to where are you getting this new parts stuff@?
You can't tell where the two burnt ends are? So that you could reconnect...
Old Feb 27, 2012 | 01:34 PM
cutthroatxxx's Avatar
cutthroatxxx
YIm trying to just put rubber vac lines off of em but I cant tell where. They run to because there broke off on the opposite end also
Old Feb 27, 2012 | 01:37 PM
Wombat Ranger
Sounds like you need to rape a junkyard truck.
Or a neighbor's when he isn't looking.
Old Feb 27, 2012 | 01:58 PM
cutthroatxxx
I think if I can figure out where they go Ill be ok.Theres one coming off with that hard plastic runs into a t&out but then its broke by the firewall&theres a line that is connected to a small valc valve&it runs nowhere&last theres the port from the egr valve that has a burnt line.So Im guessing the hard plastic one in the pic connects to either vac valve or egr valve.Just not sure which one.
Old Feb 27, 2012 | 05:33 PM
cutthroatxxx
Guess I should of looked&I would of noticed the diagram under the hood
Old Feb 27, 2012 | 06:55 PM
That woulda been too easy though.
Make sure the valve isn't screwed up, and causing the lines to melt.
Old Feb 27, 2012 | 09:10 PM
cutthroatxxx
You find a place down here yet lol I looked &seems the bottom of the egr solenoid melted&burnt the port on the bottom off. So I orderd one should be here soon
