I want bigger tires!!
Old Mar 6, 2012 | 08:51 PM
JEMRAM's Avatar
JEMRAM
Default I want bigger tires!!
I have a 2001 dodge ram 1500 with a 5.5 skyjacker suspension lift. Can i fit 37 13.50 17r. I just bought after market granit alloy rims 17x9 with a 5.74 backspacing and a 20mm offset? Will all of that fit without adding a body lift? Any rubbing?
Old Mar 6, 2012 | 09:01 PM
Matt Nickerson's Avatar
Matt Nickerson
I know you could fit 37/12.50's on a 5.5" lift. Not sure about 37/13.50 especially with 5.74 BS, its a bit much so it might not fit... well it will at least rub the control arms.
I'd also look into upgrading the axles to dana 60s if you haven't already. Some people wreck the dana 44's (and sometimes the 9.25s) with tires over ~35"
Old Mar 6, 2012 | 11:25 PM
99dodge318's Avatar
99dodge318
I hope you already have at least 4.56 gears or you will lose much more than a d44 lol
Old Mar 7, 2012 | 01:11 PM
BackwoodsRam's Avatar
BackwoodsRam
Trust me you don't want to run 37's until you get 4.88 gears and Dana 60's. I break axle shafts just going down the highway. And my truck is a dog to get moving (and I have 3.92) gears. Also you won't be able to turn the steering wheel from lock to lock with out rubbing. You need no less than 6 to keep from hitting the wheel wells at full lock
Old Mar 7, 2012 | 06:58 PM
JEMRAM's Avatar
JEMRAM
Alright with all that said. How much are the dana 60s. And how would a 3/4 axel do? Would it be able to handel the 37s with the right gears without snapping going down the highway
Old Mar 7, 2012 | 07:06 PM
offroadjosh's Avatar
offroadjosh
agreed with everyone else. i have 33s on stock axles and have broke countless ujoints, an axle shaft, 4 wheel bearings, cross shaft for spider gears, pin to hold cross shaft, pinion gear.... although i do wheel my truck extremely hard... That being said d60s will run you around 500-1200 bucks for a set depending on location, miles, damage, truck it came off, seller..etc. install is fairly easy but you will need shorter driveshafts, a hybrid joint or different yokes for the driveshafts. rear axle you need to move spring perches in 1/4 on each side. (2.5 vs 3in)
Old Mar 7, 2012 | 07:12 PM
Wombat Ranger's Avatar
Wombat Ranger
If by 3/4 you mean 3/4 ton, that is what everyone else is talking about. My 3/4 ton has dana 60's front and rear.
Old Mar 7, 2012 | 07:32 PM
JEMRAM's Avatar
JEMRAM
I have had 315 75 16r bfg alterains on my truck for about 2 years now and in the two years I've onky broke a hub assembly and a couple u joints.
Old Mar 7, 2012 | 07:44 PM
offroadjosh
add 37s and your gunna break more stuff...
Old Mar 7, 2012 | 07:45 PM
JEMRAM's Avatar
JEMRAM
So even with 35's if I don't get the 60's. Its just going to be a money pit of broken parts?
