a little fun on the DYNO!!!
Old May 10, 2012 | 04:37 PM
dodgetrucker75's Avatar
dodgetrucker75
Talking a little fun on the DYNO!!!
best run of the day @550 HP and 1100 lb.ft (in OD)..... but that was only at 40 psi of boost out of the normal 70-75 psi, and water/meth injection turned off.... enjoy
http://youtu.be/bP-UjvS3riQ
same vid, but better quality?
Old May 10, 2012 | 04:44 PM
Nice truck......
Old May 10, 2012 | 06:16 PM
lastrights's Avatar
lastrights
Not bad
Old May 10, 2012 | 07:15 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Put up the sheet.
Old May 13, 2012 | 08:45 PM
99dodge318's Avatar
99dodge318
1100 ft/lbs! That enough to pull a house down! Lol +1 on a good looking truck!
Why didn't you run it with the water/meth injection? I heard that was supposed to add a few more ponies and make things fun a little cooler.
You run 70 psi as a norm? not really a diesel guy but that seems pretty high for a d.d.
Old May 14, 2012 | 01:07 PM
Jigabop's Avatar
Jigabop
mine runs 65psi on the street...
I normally have my fueling box turned down to economy mode for daily driving though, so I run 40-45psi for daily driving if I floor it.
all it takes is 2 pushes of a button though to hit 65psi...
@op: nice truck! good to see another diesel on here in the 500hp range
Old May 14, 2012 | 02:34 PM
dodgetrucker75
well the W/M was on, but didnt make a difference, i looked afterwards at my tank, witch is mounted in the tool box, to notice that it had moved and kinked the inlet to the pump, the system i have should be worth at least 100hp, as it is a 2 stage system with 3 large nozzles, and i run a bit of a hot mix at about 75% meth
yup, i run about 70 psi on the street, the head is o-ringed whth studs and a thicker marine gasket, so it is capable of quite a bit more and still b safe, but i do run a ported internal waste gate as well as a 38mm external waste gate to get the pressure that low, otherwise it would turn a 100 psi gauge inside out.
thanks! ya was pretty irritated with the #'s was hoping see over the 600 mark this time, but got shot down again, still i cand complain too much.... DDP told me i could only make 500 with these injectors, i wanted to see 600 out them just because, but im just gona swap nozzels here soon and should be around 700, then i can start breaking stuff lol
Old May 15, 2012 | 12:06 AM
gdstock's Avatar
gdstock
Originally Posted by dodgetrucker75
....... i wanted to see 600 out them just because, but im just gona swap nozzels here soon and should be around 700, then i can start breaking stuff lol
That's why I got into engineering years ago...breaking stuff is fun...as long as someone else has to pay for fixing it!
