96 1500 4x4 keeps killing batteries
Old Jun 6, 2012 | 12:34 AM
gdstock's Avatar
gdstock
Originally Posted by jtbryant1985
can i just switch it, ive heard people say both that i can and i can not do that.
Yes...and No.
JK...Yes, but you need the same engine and tranny and same year if you can get it. Can't use a 99 for example (I don't think...well, maybe...someone else may know for sure.) But engine and tranny is important.
Old Jun 6, 2012 | 08:29 AM
Ugly1's Avatar
Ugly1
Wasn't there a diy around here about adding an external regulator? I'm pretty sure if I ever diagnose a bad regulator I'm just bypassing it if I can. That thing should have never been integrated in the first place.
BTW. Sure sounds like charging system is somehow broken...probably a bad regulator. I'd double check the connection between regulator output and battery to be sure before replacing the computer since you don't want to go through the pain and expense of tracking one down unless it's absolutely necessary.
Old Jun 6, 2012 | 09:12 AM
ECU and PCM are just different terms for the same thing. I think you are limited to swapping from a 96, or 97 model year truck, as too much changed before/after that year range.
Putting in an external regulator is an option, but, I think that would leave the CEL on constantly, whining about it. Might be some way to fool the PCM into thinking it's actually doing its job though. Haven't looked to far into that yet.
Yeah, integrating the regulator into the PCM was a stupid move on dodges part. But then, they do a fair few things that I just don't quite get.
Old Jun 6, 2012 | 12:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Old Jun 6, 2012 | 02:19 PM
gdstock's Avatar
gdstock
Dang, zman. Just like a walking library. Do you have all of these things bookmarked! Either that or hell of a memory!
Old Jun 6, 2012 | 06:30 PM
gertie240's Avatar
gertie240
yeah, really alot of thanks to you, all this help with no payback.
Old Jun 6, 2012 | 06:54 PM
gertie240's Avatar
gertie240
would it be wrong to use a ford external reg?
Old Jun 7, 2012 | 04:05 PM
zman17's Avatar
zman17
Yes, bookmarked. Otherwise I say "do a search" LOL.
Why would you not do it how the directions describe?
Old Jun 10, 2012 | 07:05 PM
jtbryant1985's Avatar
jtbryant1985
after taking in all the options and the truck sitting for a few days, i started it up 3rd try yesterday ran fro 30 maybe 45 seconds then lost all battery power and died. sucked it up bought new ecu with lifetime warranty $250, should be here middle of the week and hopefully be able to drive it home..
Old Jun 10, 2012 | 08:20 PM
gdstock's Avatar
gdstock
Let us know if that solves the problem. I would take battery and alt to FLAPS and have them checked just to make sure before risking a PCM.
