Project New Suspension: 2500 2WD
Old Jul 6, 2012 | 07:38 PM
  #21
QuadCabLuv's Avatar
QuadCabLuv
Bump. I need some input, I was wanting to do it tomorrow.
Old Jul 6, 2012 | 10:41 PM
  #22
That is a designed in steering stop. You shouldn't have lost any turn radius...... I wouldn't remove it though.....
Old Jul 6, 2012 | 10:55 PM
  #23
QuadCabLuv's Avatar
QuadCabLuv
Ive lost about 20% of my turning radius and that stop never hit before. Now its clunking against the control arm when i turn or when im turning and hit a bump. Maybe ill just grind a little of it off and grind the control arm a lil.9
Old Jul 6, 2012 | 11:12 PM
  #24
EndIsNear's Avatar
EndIsNear
I don't see why it would be a problem. You pushed your suspension down, to achieve the lift, which changed the geometry. Things are no longer going to hit where they used to. I would grind a little at a time and check. Although I've never had that issue even with 3" of lift, I guess it could be a possibility.
Old Jul 6, 2012 | 11:13 PM
  #25
EndIsNear's Avatar
EndIsNear
But I wouldn't grind on the actual control arm. Just the little nub.
Old Jul 6, 2012 | 11:17 PM
  #26
gdstock's Avatar
gdstock
I would be careful about cutting that. It is designed to hit there to prevent damage if contact is made elsewhere. Make sure to see waht else may be impacted on a hard turn.
Old Jul 7, 2012 | 12:51 AM
  #27
QuadCabLuv's Avatar
QuadCabLuv
yeah I think I will remove it and if something else is going to make contact then i will add a hard rubber bump stop there. And as far as the lift goes, you gotta remember its a 2500, it already sits higher due to the stiffer springs. So the 2" i added on to that is probably the equivalent of a 3-4" lift on a 1500....right?
