can i ryn motor without valve covers
Old Jun 30, 2012 | 08:42 PM
lastrights's Avatar
lastrights
Default can i ryn motor without valve covers
I wanna see how much truck is running with the 1.7 hs . I think my ticking may be from one of them I saw this video and was wondering they been in for about 20k miles
http://www.youtube.com/watch?v=PRsYarjT24w&feature=youtube_gdata_player
Old Jun 30, 2012 | 09:39 PM
QuadCabLuv's Avatar
QuadCabLuv
yes you can. I have done this before, but be prepared for the mess.
Old Jun 30, 2012 | 09:43 PM
gdstock's Avatar
gdstock
+1 on the mess! And make sure you top of the oil when you finish....and don't worry, the oil will burn off the exh manifolds!
Old Jun 30, 2012 | 10:04 PM
If you have an old pair of valve covers, cut the tops out... bolt them on in place of what's on there now.
Old Jun 30, 2012 | 11:21 PM
QuadCabLuv's Avatar
QuadCabLuv
This is a very clever idea. If you dont have any spares then just use a bunch of rags and please wear safety glasses. I got some hot oil in my eye when i did it and it burned like hell.
Old Jul 1, 2012 | 07:45 AM
lastrights's Avatar
lastrights
How come in the video no oil is flying anywhere ?
I just wanna see if my rocker arm is lose and inspect the springs . It may e time to just do new heads with spring and pushrods . The rocker arms should still be fine
Old Jul 1, 2012 | 09:35 AM
The oil holes are right above the pushrods, and there is a little "lip" over top of the hole... keeps oil from spraying straight up, and in the rocker where it can do some good.
While there is some oil flow in the vid, sure doesn't seem like much........ not what I am used to seeing in any event.....
Old Jul 1, 2012 | 12:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
My 68 Stang has solid lifters , I need to adjust them all the time. PITA But some one used to make clips (forget what they are called) to put on the rockers so the oil doesn't go everywhere.
Old Jul 1, 2012 | 01:00 PM
pasinby's Avatar
pasinby
While there is some oil flow in the vid, sure doesn't seem like much........ not what I am used to seeing in any event.....[/quote]
Your right , in a case like that , I would be checking some oil pressure .
Old Jul 1, 2012 | 09:35 PM
lastrights's Avatar
lastrights
So the stuck lifter noise I been hearing for over a year turned out to be a full out blown exhaust leak today , somewhere on the y pipe .
I'm worried because everything is so rusted from longtubes to the y pipe I hope they can weld up a new pipe
Reminds me of my cutout days hehe
