inexpensive things to do
Old Jul 28, 2012 | 09:28 PM
agoodman53188's Avatar
agoodman53188
Default inexpensive things to do
I'm looking for inexpensive things to do to my 99 1500. I'm looking for either performance or just appearance stuff. I've already tinted my windows and painted my rims. I was planning on lifting it and putting 33s or 35s, but now the wife and I find out she's pregnant, so that's put of the question. She said I can spend some money on the truck, but my budget has been significantly decreased. Any suggestions would be greatly appreciated. Thanks
Old Jul 28, 2012 | 10:07 PM
Fix the plenum. (about 200 or so.)
Timing chain and gears. (double roller please.)(50 for the timing set, 25 or so for gaskets, plus water pump should you decide to replace that as well.)
SCT tuner from hemifever. (265 for canned tunes. all that a basically stock motor needs.)
Harland Sharp 1.7 ratio Roller Rockers. (around 300 or so.....)
Headers? (anywhere from 100, to over 600, depends on what ya get. )
Replace O2 sensors, make sure cat isn't clogged.
Old Jul 28, 2012 | 10:19 PM
gdstock's Avatar
gdstock
And when you're good on all that, we can help you with expensive upgrades!
Old Jul 28, 2012 | 11:59 PM
agoodman53188
Is there a way to tell if the plenum has been done? When I bought the truck, I asked the dealership if it had any work done, and the sales guy rattled off a whole list of things, and he said he thinks the previous owner did something with the plenum. Then again, he said it had a tune up right b4 last winter, but the plugs were horrible, so there's no way that happened
Old Jul 29, 2012 | 12:15 AM
QuadCabLuv's Avatar
QuadCabLuv
Unless the plenum is still blown and making those plugs all nasty.
Old Jul 29, 2012 | 12:23 AM
agoodman53188
I should have clarified what I meant by the plugs being horrible, they were all rusted, and the electrodes were all pretty much gone. They looked to be original, or damn close to it
Old Jul 29, 2012 | 12:34 AM
dlyter09's Avatar
dlyter09
He was feeding you a bunch of bull just so you thought it was an awesome truck that was maintained all its life just so you bought it
Old Jul 29, 2012 | 12:36 AM
gdstock's Avatar
gdstock
Check the Plenum thread stickied at the top here. Take off TB and look inside with a light. And if plenum gasket was replaced, and bolts not shortened or aluminum plate (check with magnet through TB opening) it may need fixed again. It should be obvious looking inside.
Old Jul 29, 2012 | 08:10 PM
gertie240's Avatar
gertie240
Did any of you hear about using a small amount of pressure, less than three psi, to check for a blown plenum? I read it here on the forum and that sounds like a pretty good way to check for a blown gasket.
Old Jul 29, 2012 | 08:22 PM
That was in the TSB for checking the plenum. The idea there was to seal up the crankcase/block, (pcv, oil fill, etc.) and put a gauge on it, but, NOT to let the pressure (as that would be expected if the plenum was good.) exceed 3PSI. Otherwise, it has the chance of blowing out seals and such.
