Knock
Old Aug 10, 2012 | 09:49 AM
Ram3602500's Avatar
Ram3602500
Default Knock
On my 02 dodge ram 2500 when I hit a bump there is a knock in the front of the truck its not loud but you can hear it but the weird thing is if I hold the brake you can feel it more on the pedal, Tie rods maybe?
Old Aug 10, 2012 | 10:24 AM
QuadCabLuv's Avatar
QuadCabLuv
Maybe ball joints or tierods. Jack the front of the truck up and grab the wheel and start shaking it. If you have play side to side then inspect tie rods and wheel bearings, if you have movement from top to bottom then inspect your balljoints.
Old Aug 10, 2012 | 11:12 AM
Replaced the shocks lately?
Old Aug 10, 2012 | 01:23 PM
Ram3602500's Avatar
Ram3602500
the tie rod that goes to the pitman arm looks alittle loose and also the passenger side tie rod and no have changed the shocks but it might be time to
