2nd Gen Ram Picture thread!!! Pic whore's unite.
Old Sep 19, 2013 | 12:16 AM
  #1311
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by h3lzsn1p3r
I believe you can put a vss in the transfer case I think I read that somewhere just like the jeep tj it might be worth looking at
That is a good point. You could possibly knock out 2ish birds out. This would work fine for the 231D tcase by getting a SYE that has VSS. I wouldn't know what might change on the harness, if at all. Meaning the SYE has the provision for VSS, but do you have the sensor and harness just plugs in?
Modify the driveshaft to slip yoke one, which is a bonus actually.
Now for the V10 it has a 241 right?
To get back to pictures with the tech...saw this local here along with some other more classic dump trucks.
Old Sep 19, 2013 | 08:57 AM
  #1312
h3lzsn1p3r's Avatar
h3lzsn1p3r
^ that's beautiful and creative
yes this would be the 241( thanks for catching that) but it is the same premise only difference is now you have to use the older Chevy setup on the 241 88-99 the tail shaft and the "speedo" ring from the Chevy case will fit on the dodge case and work the speedo is actually accurate
parts required from chevy:
tone ring
tail housing
vss sensor
vss sensor pigtail
(ps. Wh1t3NuKle this should make up for my completely wrong statement the other day about the off road edition trucks lol I was tired not thinking straight)
Old Sep 19, 2013 | 09:46 AM
  #1313
redneck_ram's Avatar
redneck_ram
picked up an empty 250 gal. kero drum. let the metal collection begin! again...
Old Sep 19, 2013 | 11:49 PM
  #1314
Wh1t3NuKle's Avatar
Wh1t3NuKle
That bed is a great splice job, plus it's an operating dump bed!
That is some very useful tech about the 241C to use on our Dodge's. Kudos for sharing.
and super LoLz on the whole ORE suspension. You rock buddy.
tone ring
tail housing
vss sensor
vss sensor pigtail
Old Sep 20, 2013 | 10:27 PM
  #1315
h3lzsn1p3r's Avatar
h3lzsn1p3r
I would love to see that truck in person its a true work of art cool that the bed dumps as well ... is the cab/chassis a late 70s early 80s chev 3 ton? (looks like the 78 3 ton dump truck I have at the family campground)
Old Sep 21, 2013 | 04:10 PM
  #1316
thebullfrog's Avatar
thebullfrog
Default Finally "painted" my truck properly
Also found out the 4WD makes the most God awful clunking noise, especially while turning. I'm hoping it's just the front U-joints.
Old Sep 21, 2013 | 04:47 PM
  #1317
Purple 92 SS's Avatar
Purple 92 SS
sweet!
Old Sep 21, 2013 | 05:56 PM
  #1318
Johnn123's Avatar
Johnn123
Would of been better off to post in the picture thread...
Looks sharp, nice color What did you use the 4wd on? If it was on dry pavement thats the noise it would make. Need more details.
Old Sep 21, 2013 | 06:19 PM
  #1319
stewie01's Avatar
stewie01
Eh, not muddy enough
Should be able to make out any paint!
Old Sep 21, 2013 | 07:37 PM
  #1320
thebullfrog
Dirt/mud. It seemed to go away after a bit. I did a while back put it in 4wheel to make sure it worked and when I put it back in two it made the same noise for a few hundred feet. I almost wonder if my CAD is having a hard time fully engaging/disengaging.
I agree it's not enough, but mud is hard to come by in the Chicago suburbs lol.
