2nd Gen Ram Picture thread!!! Pic whore's unite.
Well I did manage to trash my invisa-trailer, might as well get rid of the whips too, I never use my cb at any rate.
what the hell are you going to use a CB for?! hell I barely use mine.
no need for dual antennas though..single antenna gets out further. duals are only needed to get around large trailers and they focus forward and backward and have almost no side to side pickup.
Got it for the sake of getting one, really regret it now. I preferred the look of the dual whips over the single which is why i chose them but just gonna pull em off since i use neither.
why regret? having issues parking in low clearance areas?
I had to pull my cb antenna off the mount for a couple days when my GF was in the child birth center. truck would fit in the garage by a couple inches, but antenna wouldn't clear at all. took the antenna off and had no issues parking in the parking garage.
I mounted my CB in a way that wouldn't leave permanent marks on the truck. CB mount is adapted to a stock bolt location (no holes drilled at all), and CB antenna mount is using a stock fender bolt to hold it down. (also no holes drilled)
its out of the way and don't look bad though, so I don't mind it being in there...comes in handy every now and then when truckers point out speed traps or accidents in a blocked lane...
mine fits in only a couple parking garages.
then there are some that I can't go in due to weight limits..
my truck weighs over 7,000lbs. weight limit in some garages is posted as 6,000lbs lol...don't need truck to fall through the floor...
