Found out something cool last night.
Last night I was messing around with formulas to find rpms with different tires and gears and when I calculated rpms at 60 with the tires and gears the door sticker says I have- 3.21x.69x60x336/29.3=1524. Weird, at sixty Im runnin about 1700ish so I switched it around and tried 29.3x1700/(60x336)=2.47 and 2.47/.69=3.58 which means I must have 3.55 gears. So I apologize for any misstatements Ive made while under the impression I had 3.21s
Trending Topics
Here's a good link to try, it calculates your old tire size, new tire size, current gear ratio. It will give you suggested, high and low gears and effective ratios. Remember just because you running 4.10s for example with 33" tires, your effective ratio is not 4.10. More like back to factory 3.55.
http://www.4lo.com/calc/geartire.php
