New to the forum, just bought this lil guy.
Old Dec 14, 2012 | 04:11 PM
  #31
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You did the plenum yourself, right?
Same process mostly. It is actually suggested that if you have the means to go ahead and replace the timing set and water pump while doing the plenum.
If you do replace it, get a nice double roller set.
Old Dec 14, 2012 | 04:16 PM
  #32
MurkyRivers1500's Avatar
MurkyRivers1500
Yeah did the plenum myself. The water pump was just replaced before I bought the truck (the person I bought it from gave me receipts for everything she had done, basically 8,000 dollars in the last two years) Unfortunately none of the work included the timing chain, although she did buy new heads.
Ill look into the double rollers.... I hear it makes a nice sound
Old Dec 14, 2012 | 04:18 PM
  #33
dodge dude94
idk about the sound but the performance bump is nice I hear.
I have yet to do mine.
Old Dec 14, 2012 | 04:26 PM
  #34
MurkyRivers1500
Trying to find who sells them.... any links?
Old Dec 14, 2012 | 04:31 PM
  #35
dodge dude94
Rockauto for one.
That's likely where I'll get mine, Cloyes Double Roller with 3 keyway cam gear.
Old Dec 14, 2012 | 04:44 PM
  #36
MurkyRivers1500
http://www.summitracing.com/parts/cca-3103 < definitely not that one, looks like its for the older engines.... 1988 and earlier.
Or
http://www.summitracing.com/parts/cca-2103/overview/
Old Dec 14, 2012 | 05:01 PM
  #37
dodge dude94
I think the bottom one should work.
Just make sure it's for a 5.2/5.9 Magnum, an LA model won't work.
Old Dec 14, 2012 | 06:20 PM
  #38
guzman's Avatar
guzman
I don't think that part# 2103 is correct, looks like for a older model 360. Search more.
Old Dec 14, 2012 | 06:30 PM
  #39
guzman's Avatar
guzman
I still had the box from my Cloyes double set...part #C-3028X is the one with the extra machined slots if you want to run stock, retard or advance timing.
Old Dec 15, 2012 | 01:52 AM
  #40
Wombat Ranger's Avatar
Wombat Ranger
A timing chain will not make the obnoxious sound that timing gears make. I bet that's what you are referring to.
