transmission linkage
Old Nov 17, 2012 | 02:21 PM
neiasden's Avatar
neiasden
Default transmission linkage
when i put my truck in drive it shows neutral on the indicator, i end up in second alot... how do you fix this ?? thanks,,, remember i am a idiot.. i need deep explanations,, lol
Old Nov 17, 2012 | 03:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you dowloaded the service from the DIY/FAQ section or bought a Haynes ? Could be linkage or a simple adjustment under the steering column.
Old Nov 17, 2012 | 03:21 PM
Halojm's Avatar
Halojm
Here's the under the dash fix.
https://dodgeforum.com/forum/2nd-gen...cator-fix.html
Old Nov 17, 2012 | 03:24 PM
zman17's Avatar
zman17
Originally Posted by Halojm
That's for a 97. 98 and up is different.
Old Nov 17, 2012 | 03:26 PM
Halojm's Avatar
Halojm
They should have specified that in the thread
Old Nov 17, 2012 | 05:44 PM
zman17's Avatar
zman17
Probably, but that same adjustment is a lot easier on a 98 and up. Remove the knee panel and adjust the screw. But the OP still needs to make sure it's not the linkage itself.
Old Nov 17, 2012 | 09:25 PM
gdstock's Avatar
gdstock
+1. Make sure linkage is correct, then adjust indicator. Doing the other way would not fix it. If you are beween gears or in the wrong gear, I suspect linkage. Download the referenced manual for instruction. One bolt fix.
Old Nov 18, 2012 | 11:23 AM
neiasden's Avatar
neiasden
you guys all know so much, i wish ez to me was the same as for you, ez for you all is complex to me. lol, but i know where to start now, thanks so much..
Old Nov 18, 2012 | 11:27 AM
neiasden's Avatar
neiasden
where can i down load the manual, im sorry, im legally blind and have a terrible time reading, hate to waste your time too..
Old Nov 18, 2012 | 12:17 PM
gdstock's Avatar
gdstock
2001 Service Manual
1999 BR (Regular Cab)
https://docs.google.com/viewer?a=v&p...thkey=CKHA1O4N
1999 BE (Extended Cab)
https://docs.google.com/viewer?a=v&p...thkey=CLDX1IMG
