loose door,,, sqeaky
Old Nov 23, 2012 | 06:31 PM
neiasden's Avatar
neiasden
Default loose door,,, sqeaky
my driver side door seems to be loose or lost some rubber, when i go on a bumpy road it squeaks, if i hold it tight, it stops, making me think its loose..?? whats the best way to make the door tighter ?? thanks..
Old Nov 23, 2012 | 07:20 PM
kejobe's Avatar
kejobe
In which way is it loose? If its loose when you close it fully (where you can still push the door closed a little more) adjust the striker in the door jamb.
If its loose by moving up and down when the door is open, the hinge pins need replaced.
Old Nov 30, 2012 | 07:57 AM
neiasden's Avatar
neiasden
thanks for the reply,, im not sure, it just squeaks when im on a little bumpy roads, drives me nuts, but when i roll the window down, and pull the door in tight it stops making me think something is lose...
Old Nov 30, 2012 | 11:32 AM
kejobe's Avatar
kejobe
Try moving the stricker (the part on the jamb not the latch) in (towards the inside of cab) about 1/8th of an inch. See if that helps.
