Question On Catalytic Converter
Old Jan 9, 2013 | 05:15 PM
  #21
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by stewie01
I thought you had but couldn't remember. But you can bet the truck that the cat is clogged.
How can you say that?
I don't see the OP posting about engine operation problems....
Old Jan 9, 2013 | 05:28 PM
  #22
Arde's Avatar
Arde
Originally Posted by Big Joe C
So with it being clogged, other than robbing power, will it hurt any to drive it till summer when I replace everything???
The increased exhaust back pressure not only robs power, but it can raise combustion chamber temps. which can lead to head cracking, a pretty common problem on these thinwall head castings.
Old Jan 9, 2013 | 05:45 PM
  #23
stewie01's Avatar
stewie01
Just using my own personal experience. I cut my cat out 9 months after I did the plenum change, not because of engine performance issues, the truck was running perfectly, but because I wanted it gone, and sure enough it was clogged up. Truck is much more responsive and even holds overdrive much better with the cat gone too..
Old Jan 9, 2013 | 05:50 PM
  #24
Johnn123's Avatar
Johnn123
How does it sound without the cat? You got a muffler on there?
Old Jan 9, 2013 | 05:54 PM
  #25
stewie01's Avatar
stewie01
Stock muffler at the moment. Not the best video but;
Little rapsy when you let off from getting on it. It's quiet when driving though, you don't notice it.
Wanna put in a MagnaFlow sooner or later...
Old Jan 9, 2013 | 06:03 PM
  #26
Johnn123's Avatar
Johnn123
I actually quite like that! Might have to pull mine off, cept I got emissions round here -_-
Not to thread jack but how did you remove and install pipe?
Old Jan 9, 2013 | 06:31 PM
  #27
stewie01's Avatar
stewie01
Removing the pipe is a PITA because there isn't much room between the top of the pipe an the bottom of the cab, but I used a hack saw and an air grinder, then welded in the new pipe, which for the same lack of clearance on the top is a PITA too.
Old Jan 9, 2013 | 06:44 PM
  #28
Johnn123's Avatar
Johnn123
It all the same size? Ive never actually looked that far up on mine lol
Old Jan 9, 2013 | 06:52 PM
  #29
stewie01's Avatar
stewie01
No. The cat inlet is 3" and the exhaust pipe after the cat is 2.5". Had to get creative as none of the part stores in town had a 3" to 2.5" reducer, bastards.
Old Jan 9, 2013 | 07:14 PM
  #30
oxymoron29's Avatar
oxymoron29
+10000 to that. Had a SIGNIFICANT increase in low end torque and overall performance when switching to an O/R Y, even on a 100k km truck. The driveability on the highway was so much better, and I gained around 2mpg.
Feel lucky that you have a a SI/SO cat that you could just cut and replace. I have a '97 and had to go with a Jeg's offroad Y and which I need to swap out for the stock one every 2 years to do my emissions test. It is a PITA but totally worth it for the substantial performance/mileage gain/sound increase.
BTW you really need a muffler for that thing, it has the potential to sound infinitely better than it does now
