Sct tuner question
Old Feb 11, 2013 | 06:29 PM
Weazle23's Avatar
Weazle23
hemifever said my pcm was the degraded flash. so hopefully it improves it quite a bit
Old Feb 11, 2013 | 08:25 PM
gdstock's Avatar
gdstock
You WILL be happy with it!
Old Feb 15, 2013 | 12:08 PM
Weazle23's Avatar
Weazle23
Ok got tuner. Did it in parking lot after work. Definately the easiest mod i've ever done. Did the 87 octane tune. Noticed a slight difference. Havent tried the 89 or 91 yet. Probably alot bigger difference after i install one of those.
Old Feb 17, 2013 | 06:02 PM
gdstock's Avatar
gdstock
If plenum is good and other things as well, you should have noticed more than a slight difference, expecially during acceleration. I don't think I have ever changed from 87 tune (since I run 87 oct gas...).
Old Feb 19, 2013 | 09:58 AM
Brian_'s Avatar
Brian_
i didnt notice a huge difference with mine, although im only running 87 due to pinging on 91 and 93 tunes
Old Feb 20, 2013 | 04:23 AM
tbone360's Avatar
tbone360
did you change to the 180 tstat?
Posted from Dodgeforum.com App for Android
Old Feb 20, 2013 | 08:48 AM
Brian_'s Avatar
Brian_
yes, although i through cel p1281 because of that with this time of the year being too cold. my new fun cel is the p1740, something with the tranny.
Old Feb 20, 2013 | 09:22 AM
ChillyPhil's Avatar
ChillyPhil
I don't notice any pinging but i don't have the tstat installed yet. Hemifever said it'll be fine running it with the stock tstat throughout winter because it's cold enough.
But i got the tuner awhile back and have it on the 91 tune with 33x12.50s and it carries them right along. But i didn't do any tune up or plenum fix yet. I'll be doing them in the future though.
Old Feb 20, 2013 | 09:37 AM
redneck_ram's Avatar
redneck_ram
got my tuner yesterday. loaded the 93 tune right away cause i had 93 in the tank. havent had a chance to test out the power yet. got an engine(360) in the bed, and the plow is on. motor is coming out friday afternoon, and we're getting snow saturday night, so ill test it while plowing.
Old Feb 21, 2013 | 06:42 AM
Weazle23's Avatar
Weazle23
i installed the 91 last nite. going to see how it does on my way to work. i have another question. it says it can be used to read and clear codes. is that only on dodges or can that be used on any obd2 vehicle?
