Sct tuner question
Old Feb 21, 2013 | 07:54 PM
  #21
Brian_'s Avatar
Brian_
i would assume any vehicle, since it doubles as a scanner.
Old Feb 21, 2013 | 08:00 PM
  #22
gdstock's Avatar
gdstock
Plug it in something else and see.... I never tried mine on anything else - but I have two regular OBII scanners and the Snap On. I have only used the SCT to load tune, and once an update from Sean....
Old Feb 21, 2013 | 08:33 PM
  #23
stewie01's Avatar
stewie01
Still want to order one. If the BW Solenoid does the trick for my transmission I think I'll get one.
Old Feb 24, 2013 | 02:01 PM
  #24
Weazle23's Avatar
Weazle23
tried it on wifes neon. said there were no codes so looks like that function works on all obd2 vehicles. i was used to have the predator tuner on my old mustang where once you used it on the car it was locked to that car.
Old Apr 20, 2013 | 07:59 PM
  #25
philipreza's Avatar
philipreza
my transmission takes a while to shift out of 3rd it goes 4500 rpms before it shifts. but its never slipped. will a tuner correct the late shifting if i put it on a dyno and have a tune specifically for my truck?
Old Apr 21, 2013 | 01:59 PM
  #26
gdstock's Avatar
gdstock
If something else is causing the late shift - NO. Don't know what putting it on a dyno would do. Check TV cable to start and make sure it is correct..
Old Apr 22, 2013 | 12:57 AM
  #27
philipreza's Avatar
philipreza
how would i know if tv cable is fine? It only does the late shifting when the pedals to the floor
Old Apr 22, 2013 | 09:41 AM
  #28
That's pretty typical for the dodge automatics.... the governor pressure sensor isn't the best... at large throttle openings, it can't do its job well, so the PCM gets rather confused, and won't shift. You can try replacing it.... but, it may or may not help.
Old Apr 24, 2013 | 01:20 PM
  #29
philipreza's Avatar
philipreza
How was the mpg difference with your trucks guys?? That's the only reason I want a tuner lol
Old Apr 24, 2013 | 01:32 PM
  #30
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Usually 1-2 mpg. But that is usually lost due to the heavier right foot.
