Squeeling belt...need input
Old Feb 12, 2013 | 06:50 PM
kejobe's Avatar
kejobe
Oh, and P.S.- Thank you all for the help. I know this crap has been covered to death.
Except for Stewie, your just being an @ss!!
Old Feb 12, 2013 | 07:00 PM
I just got one from advance..... it works fine, but, the main spring housing for the tensioner is larger diameter than the stocker, have to space the coil out a quarter inch, else the tensioner rubs on it. Not a good idea.
Old Feb 12, 2013 | 07:48 PM
kejobe's Avatar
kejobe
Did you get the Light Duty or the Heavy Duty. I'm seeing both on their site but only the LD at the store.
I'm wondering if the Heavy Duty would be better...Or maybe its just a BS marketing gimmick. I mean no one else has LD vs. HD tensioners.
The wifes gonna kill me. Another belt, another tensioner. Plus needing all new steering linkage and alignment....What next???? (Please dont answer that)
Old Feb 12, 2013 | 07:51 PM
I don't recall being given a choice....
Old Feb 12, 2013 | 08:07 PM
gdstock's Avatar
gdstock
Not on my Ram, but on my Yota, I just replaced the bearing. I think it was a 6203 (common bearing). Is there a bearing suppy place near you? I have thought about pulling mine off the Ram and replacing it...wait...I may have. I cannot remember. But whichever one it was it was a 6203 bearing.
Old Feb 13, 2013 | 12:25 PM
Matt Nickerson's Avatar
Matt Nickerson
If you're looking to buy a new belt and tensioner, I would buy the tensioner first to see if it fixes it. If it doesn't return it and buy a belt.
Old Feb 13, 2013 | 01:47 PM
kejobe's Avatar
kejobe
Ok update: I just spent the last several hours looking into this. The belt looks good. So does the tensioner. Started checking pulley alignment. JACKPOT!!!! I hope anyway. Tha a/c pully was out.
What happened is one of the times I pulled the a/c compressor and bolted it back on, I bolted it out of alignment. Even though there is NO normal adjustment in it, there is enough slop for it to be moved back and forth about 1/16".
Summary: It was making noise when I took it apart today. I found the a/c pulley out. Moved it back about 1/16". Put it back together and started it. NO MORE NOISE!!!! Hopfully it was the problem.
Old Feb 13, 2013 | 02:46 PM
Jigabop's Avatar
Jigabop
Originally Posted by Jigabop
sounds like it...might be dragging or not in good alignment with the rest of the pulleys causing the belts to wear faster...once the coating on the belts are gone they start to squeal...another bandaid to stop squeal is holding a crayon against the belt while its running.. crayon coats it in wax which stops the squeal.
close to what I first said
Old Feb 13, 2013 | 04:20 PM
kejobe's Avatar
kejobe
Yeah, yeah, yeah. But see, why should I listen to you? You've got a cummins!! Cough (@sshole) Cough...
Old Feb 13, 2013 | 08:28 PM
Jigabop's Avatar
Jigabop
aside from the sexiness that is a cummins...we all have the same crap dodge accessories bolted on to our motors
and the cummins ain't my only ride...got a chevy S10 too.. 4 banger gas guzzler. would have had the same issue on it but I caught it before putting the belt on...
put a new alternator on it and the belt was a rib out of alignment. bent pulley. returned for another one. new one lined up perfect.
