ideas
Old Feb 24, 2013 | 11:18 AM
mickey mouse's Avatar
mickey mouse
Default ideas
new to dodge noral gm owner yet love a dodge so i got one and kicking my self in the a** for it for some reason it stalls out and fuel gauge goes to empty and wont start then all the sudden the gauge goes back up and it will start again i replaced the crank and cam sensor with no results please help
Old Feb 24, 2013 | 11:23 AM
dhvaughan's Avatar
dhvaughan
can you check fuel pressure with a gauge when this is happening.
and/or check for the sound of the fuel pump when you turn ignition on. it should whine for a short 1-2-3 seconds before it cuts off due to engine not turning (normal ASD behavior)
it sounds like you are loosing power and connection to fuel pump and gas tank sending unit.
Old Feb 24, 2013 | 11:46 AM
mickey mouse
so what would i do to fix the asd problem
Old Feb 24, 2013 | 11:53 AM
Figure out what is causing the ASD event.
Grab the 01 service manual from the faq section, and check out the troubleshooting steps in there.
Old Feb 24, 2013 | 12:00 PM
dhvaughan's Avatar
dhvaughan
i don't think its an ASD event. i think you're loosing all signal to fuel pump/sending unit. as in wiring problem. check the connections on the top of the tank, and verify loss of pressure.
Old Feb 24, 2013 | 12:03 PM
merc225hp's Avatar
merc225hp
Originally Posted by dhvaughan
It sounds like you are loosing power and connection to fuel pump and gas tank sending unit.
+1 on that, possible plug at the pump as well.
Old Feb 24, 2013 | 01:53 PM
mickey mouse
the pump runs fine if i hard wire it yet it still wont start and the asd relay keeps clicking when it dosent start
