to large of tires
Old Mar 2, 2013 | 12:45 PM
PmuLLin's Avatar
PmuLLin
Is it really that hard? I don't mind investing in proper tools as Long as before I can have instructions of some sort, taught my self everything else
Old Mar 2, 2013 | 12:48 PM
Procedure is in the service manual.... Download the 01, and read thru the process. It isn't that it is really difficult....... gears are just REALLY REALLY REALLY picky about how they are set up. Do it not quite perfect, and you can smoke your gears in pretty short order. Get it set up right, and they will last pretty much forever. Tools for the job can be a bit pricey....... compare the cost of tools, with paying someone else to do the job, gonna be a close call.
Old Mar 2, 2013 | 01:05 PM
merc225hp's Avatar
merc225hp
Have a browse through this as well as the FSM.
https://docs.google.com/document/d/1...it?usp=sharing
Old Mar 2, 2013 | 05:38 PM
PmuLLin's Avatar
PmuLLin
might get laughed at for this but a guy a work said a power programer/tuner might help out a little but as long as i could get one that i could change the tire size summit had one for a couple hundered, stupid idea??
Old Mar 2, 2013 | 06:56 PM
gdstock's Avatar
gdstock
Originally Posted by CSDavies26
If you've never done gears before than I don't recommend doing it yourself unless you have a friend or someone who has done them multiple times. Find a reputable shop that has done gear swaps before and knows how to properly brake them in, etc.
I have torn into nearly everything automotove - except the differential. Not that I would be afraid to do so, just have not had the need. But if I wewre to do it, I would try it on a project car, not my daily driver. I have worked on large industrial gearboxes, but these do tend to be quite unforgiving, with serious consequences if not done proprely.
That said, the best way to learn is do. But having someone with you that has done it before would be beneficial.
Some programmers can compensate the speedo for change in tire size, but this does nothing to reduce the drivetrain strain created by increased tire size. THis is not a solution.
Old Mar 2, 2013 | 09:23 PM
PmuLLin's Avatar
PmuLLin
Alright then ill probably just have to stick with the tires I have now since ill be starting the whole starving technical college student thing again, can't spend 4k for tires and gears ha, unless anyone wants to donate!!! Can 2500 switch to 35's without a problem?
