Tire Question
Old Mar 5, 2013 | 02:47 PM
Killerharen's Avatar
Killerharen
Default Tire Question
My grandpa has a set of tires that came on his jeep when he got it and are now collecting dust in his basement. we think that the are the same size thats on my truck and i need new tires. can they safely be used on the truck or are they made for lighter use such as his jeep? i do not have any more information on the tires at the moment.
Old Mar 5, 2013 | 02:51 PM
stewie01's Avatar
stewie01
Can't tell you without some specs on the tire.....
Old Mar 5, 2013 | 02:54 PM
merc225hp's Avatar
merc225hp
If the letters/numbers start with a P they are no good to you, if they start in a LT then you might have a chance. Need more info.
Old Mar 5, 2013 | 02:57 PM
Killerharen
ill try to vist him this weekend to take a look at them. im crossing my fingers that they work
Old Mar 5, 2013 | 03:19 PM
kejobe's Avatar
kejobe
Mine originally came with P metric tires.
Old Mar 5, 2013 | 04:14 PM
stewie01's Avatar
stewie01
My truck had P rated tires on it when I first got it. Never had any problems.
Old Mar 5, 2013 | 04:17 PM
merc225hp's Avatar
merc225hp
P = passenger car tire specs
LT = Light truck rated tire specs
Look at the load rating for a P tire compared to a LT tire of the same size. To each there own but I will always use a LT tire on a truck.
Old Mar 5, 2013 | 05:01 PM
Jigabop's Avatar
Jigabop
if you don't plan on hauling any heavy loads, any tire will work...if you run heavy loads (more than a few hundred pounds in the bed) then you need LT tires..
my S10 has passenger tires on it and I have ran with 1000lbs in the bed... tires aired up to max of course..it sat nose high, but it handled it.
had the bed full of 80lb cement bags and was only going 15 miles with them.
of course the S-10 can get away with that because it weighs a lot less than your average passenger car...but yours being a full size has about 2000+lbs on my S10... so i wouldn't put more than a few hundred lbs in the bed
Old Mar 5, 2013 | 05:11 PM
kejobe's Avatar
kejobe
As long as you dont go over the load limit of the tire, your fine. The load limit is on the side of the tire.
Old Mar 5, 2013 | 05:15 PM
You honestly expect anyone to answer that question without any details whatsoever???
