(Finishing) techningeer's 6.0L (367) Build
Old Mar 15, 2013 | 04:53 PM
aofarrell2's Avatar
aofarrell2
Default (Finishing) techningeer's 6.0L (367) Build
So I've had to put the transmission conversion project on hold, because the engine needs some work and I can't risk running the engine with a bad bearing. So I'm going to have to pull the transmission so I can pull the engine COMPLETELY.
So I'm gonna tear the motor COMPLETELY apart, every last little bit. It's gonna get new pistons/rings, cam, timing chain, SCT tune, Mopar performance lifters, new bearings (crank, rods, and cam), and new dizzy. The crank will most likely have to be ground. That's the basics summed up there . I'll be reusing my heads since they are basically brand new, but I'll have to check the oil pump to be sure it's reusable. I know it's new as well, but I have a hunch it's contributing to the noise. It'll also get better valve springs. More specifics later .
Old Mar 15, 2013 | 05:25 PM
dlyter09's Avatar
dlyter09
6.0?? 367??? I must be confused...
Old Mar 15, 2013 | 06:03 PM
aofarrell2's Avatar
aofarrell2
Do some math. Stock bore and stroke is 4.00"x3.58" (5.9L 360CID), respectively. That is what the engine is at right now. The pistons I will be using require the engine to be bored out slightly farther, so the engine will then be a 4.04"x3.58" (6.0L 367CID) after that. So my title is accurate
Old Mar 15, 2013 | 08:10 PM
dlyter09's Avatar
dlyter09
Well you made no mention of that in your original post.. We aint mind readers here bud... Geeze come on you noob... Get with the program and put all info in your posts...
Old Mar 15, 2013 | 08:15 PM
stewie01's Avatar
stewie01
^^ What he said!
Good luck!
Old Mar 15, 2013 | 08:19 PM
Jigabop's Avatar
Jigabop
6.0L is a bad number...
6.0L's are known to fail from most makes...
ford especially lol
Old Mar 15, 2013 | 08:21 PM
dlyter09's Avatar
dlyter09
LMAO!!! I was thinking that myself haha
Old Mar 15, 2013 | 08:48 PM
Wombat Ranger's Avatar
Wombat Ranger
Yea do some math stupid.
Old Mar 15, 2013 | 09:00 PM
Hahns5.2's Avatar
Hahns5.2
Gonna do all that and keep the stock heads
Old Mar 15, 2013 | 09:08 PM
aofarrell2's Avatar
aofarrell2
LOL... I purposely did that... Had to give you a hard time ya know!
Edit: I was actually short on time unexpectedly when I was typing that.
ford especially lol
Mostly Powerjokes. Cause they have a poor injector design, poor EGR design, poor design in general. I'm not too worried about a 6.0L Magnum. But maybe I should ask, what is it that usually fails on a 6.0L?
I've got HD aftermarket heads. They can handle the slight compression raise.
