pop
Old Mar 29, 2013 | 12:16 PM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
Default pop
So for a while now i have noticed a pop coming from under my truck when i am taking off from a stop sign or stop light. I figured out if i put it in neutral with the truck off and roll it forward it will do it whenever i want. So one day i got under it and had a friend roll it forward and i have detirmined that it is coming from the tranny. Yay... Anybody have any ideas??
Old Mar 29, 2013 | 12:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Since it's a 4x4 from reading this thread, I'd say check the hub assemblies, axle u joints and both driveshaft u joints. Balljoints and lower shock bolts too.
Old Mar 29, 2013 | 12:45 PM
98Dodgeram360V8Mag
ok. the driveshaft ujoints were replaced in like november. lol
Old Mar 29, 2013 | 12:51 PM
gdstock's Avatar
gdstock
There was one post. How did you figure that out? It isn't in his sig! (Tha magical powers of a mod!)
OK. So are you deciding to NOT check them? The parts could have failed, something not tightened correctly, etc. I would check anyway just to eliminate them as a possibility. Troubleshooting is about eliminating possibilities to move to another.
Old Mar 29, 2013 | 12:52 PM
zman17's Avatar
zman17
Both drive shafts and the joints?
Old Mar 29, 2013 | 12:53 PM
zman17's Avatar
zman17
Because as of today, he has posted several times in several different threads.
Old Mar 29, 2013 | 01:02 PM
gdstock's Avatar
gdstock
Missed that because I am only casually reading....
Old Mar 29, 2013 | 01:21 PM
guzman's Avatar
guzman
Default U-joints
So I take it you were laying under the truck while your friend rolled the truck and the noise came from the tranny area???? Did you follow the rolling truck while on a creeper to determine this??? Anyway do what the others said and checkout the U-joints even if recently replaced doing so with the rear end jacked up and with your friend turning the rear wheels. A popping coming from the transmission itself just does not sound right. If you hear and feel nothing then (have your hand on the driveshaft when its turning) proceed elsewhere.
Old Mar 29, 2013 | 02:46 PM
98Dodgeram360V8Mag
The ujoints. And sorry, its not when i roll it forward in neutral, its when i do that and then put it in park and then roll it forward.
Old Mar 29, 2013 | 02:49 PM
98Dodgeram360V8Mag
No, i wasnt on a creeper but i had him do it several times and it sounded like it was comming straight from the tranny. Note: it doesnt do it constantly. Just when taking off from a stop. And sometimes when it shifts.
