beginningjockey's 360 to 318 swap
Old Aug 12, 2013 | 01:45 PM
  #71
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
if you didn't have a return line then you would most likely have vapor lock issues since big blocks were more prone to vapor lock when return line was disconnected than small blocks were. your return line should T off your fuel filter by your fuel pump.
Okay, I'll look. It's hard to start SOMETIMES but I figured that was because of the carb.
BTW, techjockey.
  #72
merc225hp's Avatar
merc225hp
At least I know for sure that my thought process wasn't wrong...
Running pig rich or fat will kill a motor just as fast as running it lean. 6psi is average for a carb setup.
Old Aug 12, 2013 | 01:49 PM
  #73
dodge dude94
Mine only runs that rich when it's 30 degrees outside.
Crazzy, I just checked: no return line. Then I remembered something: this truck had an auxiliary tank in the bed. So the fuel system on this truck isn't factory.
Old Aug 12, 2013 | 01:56 PM
  #74
merc225hp's Avatar
merc225hp
Set the choke up right and that will go away, that and let it warm up for a bit. The aux tank will have nothing to do with the return line if it ever had one which I don't think it did. I will check my books later on and see if they had one or not.
Old Aug 12, 2013 | 02:04 PM
  #75
dodge dude94
The choke is likely set up for Texas. lol I likely won't be running it much in the winter (hopefully) so it's a non-issue at this point.
Old Aug 12, 2013 | 05:36 PM
  #76
aofarrell2's Avatar
aofarrell2
I am not running it rich enough to wash the cylinder walls, I know that because I HAVE done that before. Now the puffing black smoke was a little bit of a joke, I turned it down slightly from where it was smoking whenever I'd stomp on it, but I do run a tad on the rich side, because in my experience it helps with performance. Most of the time it never smokes at all, and doesn't smell rich either.
As far as fouling spark plugs, never had a problem with that with my method. I'll get around to pulling them one of these days and see what they indicate. Anyone wanna bet ?
Old Aug 12, 2013 | 05:40 PM
  #77
Johnn123's Avatar
Johnn123
I'd imagine they would have worn like regular, maybe, have a bit of fuel on em from being rich.
Old Aug 12, 2013 | 05:41 PM
  #78
crazzywolfie's Avatar
crazzywolfie
what are you adjusting that would make it smoke when you stomp on it? none of the screws on my carb will make the engine smoke when i stomp on it.
Old Aug 12, 2013 | 05:43 PM
  #79
dodge dude94
If you need your carb to run rich to get performance out of it, you have a problem with your secondaries.
Old Aug 12, 2013 | 05:48 PM
  #80
aofarrell2's Avatar
aofarrell2
I'm talking about the external fuel regulator. I'm running 7PSI, seems to work good.
DD, I don't see why it'd be making great power if the secondaries weren't working. I will pull the plugs though and see what the whole story is.
